Sodium Replacement With T5 - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 12:40 PM   #1
Average Joe
Question
Sodium replacement with T5
Honestly, there probably not sodium but, they are old, power suckers. I am replacing them w/ 8' four bulb, T5 fixtures. I pulled one the old fixture and found the hot and neutral with the ground going nowhere. Just a piece of ground wire going from the light into the Jbox that had no termination point in the box.
The T5 wiring has a hot line, neutral line, gray with red tracer line (???) and a grounding screw.
What is the gray line and where does it go to?
How do I ground this out?
If it helps, I have 6 banks of 3 each (old lights) to replace.
AKLON is offline   Reply With Quote
Old 03-07-2012, 02:16 PM   #2
Missouri Bound's Avatar
It's very possible that wire is for a different voltage....perhaps 277V. No information on the ballast?
Do you want it your way or the right way?
Old 03-07-2012, 04:52 PM   #3
Electrician
Rewards Points: 802
Check the ballast, but I have never seen a fluroscent ballast with a multitap. Do you have a dimmeable ballast in those fixtures.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
frenchelectrican (03-07-2012)
Old 03-07-2012, 05:30 PM   #4
Average Joe
Checked the balast. Appears that it is for a switch. Capped it with the neutral and half the lights came on. Capped it with the hot and they all came on. Been on for 2.5 hours and seems fine.
Any issues with that I should worry about?
Old 03-07-2012, 05:36 PM   #5
Electrician
Rewards Points: 802
Is there two ballast in the fixture?
Old 03-07-2012, 08:17 PM   #6
Julius793's Avatar
The t5 ballasts I did the other day the gray with red stripes connects with the black. However the one I replaced it with the gray went with the white, so it depends look at the wiring diagram.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 03-07-2012, 10:27 PM   #7
" Euro " electrician
frenchelectrican's Avatar
To AKLON.,
You have what we called either multi level ballast or mulit lamp ballast either words mean the same thing and you have extra conductor that is a giveaway for mulit level ballast so you have either full lamp on or half lamp on depending on the numbers of tubes is on.
To change the light level you will have to refered to the wiring diagram there is two ways to do that.
And you should able get the wiring diagram on the ballast itself if not just snag the model number we will go from there.
Merci,
Marc
Sash Replacement vs. Insert Window Replacement dcd22 Windows and Doors 15 07-27-2014 04:39 PM
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
replace replacement windows theone Windows and Doors 3 10-19-2011 09:16 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
