Old 10-11-2010, 05:28 PM   #1
Socket plate is loose
How does the H7ICT socket plate attach to the inside of the can??
jdzhere is offline   Reply With Quote
Old 10-11-2010, 05:49 PM   #2
nap
You talking to me?
nap's Avatar
what is an H7ICT?
nevermind, I foound it.
http://www.cooperlighting.com/specfi.../ADV042486.pdf
It appears the socket clips into the end of the trim.
Old 10-11-2010, 08:48 PM   #3
Master Electrician
The lamp socket clips into the the socket plate. The socket plate attaches to the housing with a small bolt and wing-nut, both of which can be easily lost if they have come loose. See nap's link above.
brric is offline   Reply With Quote
Old 10-11-2010, 09:05 PM   #4
" Euro " electrician
frenchelectrican's Avatar
There are some trim that you may have to remove the light socket holder { Item B in Nap's link } and clip right on the trim itself I know few airtight trims will have to do this anyway and of course eyeballs trim the samething as well.
Merci.
Marc
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 07:54 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 09:54 AM
HALO H7ICAT Socket Plate Adjustment BigJimmy Electrical 3 05-28-2009 02:25 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
