So I'm Moving The Window This Weekend And Removed A Wire . . . - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 11:20 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
So I'm moving the window this weekend and removed a wire . . .
Wire run from the panel to an outside breaker box for a hot tub service.
The wire is a 6-3 w/g romex wire. What size circuit is allowed on this size of wire? I'm thinking this might be able to be re-used for a sub panel?
Journeyman Plumber
Old 01-28-2012, 11:26 AM   #2
Just call me Andrew
Rewards Points: 1,020
Depending on the distance (voltage drop) you can run max 55 amps on 6/3.
You can get a 55 amp breaker to feed your panel, or, If your calculated load is 55 or less, you can use a 60A breaker.
Andrew
secutanudu is offline   Reply With Quote
Old 01-28-2012, 11:39 AM   #3
Electrical Contractor
kbsparky's Avatar
I've never seen a 55 Amp breaker. Not listed in the "standard" size chart in 240.6(A) of the NEC either ...
-KB
Old 01-28-2012, 12:03 PM   #4
Julius793's Avatar
Copper?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-28-2012, 02:38 PM   #5
joed's Avatar
Rewards Points: 12,924
60 amp sub can be attached to that cable.
Old 01-28-2012, 03:04 PM   #6
Just call me Andrew
Me either....but I have been told by others around here they exist....
For me, I used 6/3 with a 60A breaker
Andrew
Old 01-28-2012, 04:45 PM   #7
DIY staff
Rewards Points: 7,174
You can buy them but you must pay cash using a $25 dollar bill--
secutanudu (01-28-2012)
Old 01-28-2012, 06:04 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-28-2012, 06:06 PM   #9
plummen's Avatar
Of course up till a month ago i had never seen a 25a breaker either though,but they do exist
Old 01-28-2012, 06:40 PM   #10
25 amp breaker
http://www.superbreakers.net/thqp225...FUHCKgod0i5-sw
womp there it is!
Hardway is offline   Reply With Quote
Old 01-28-2012, 09:20 PM   #11
Missouri Bound's Avatar
Right now I'm set up for $55 bills.....next week the $25's.....how many do you need??
The Following User Says Thank You to Missouri Bound For This Useful Post:
oh'mike (01-29-2012)
My window between siding and drywall... jamieofansa Drywall & Plaster 2 09-05-2010 08:55 PM
