Snoc Garden Light Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 04:05 PM   #1
Rewards Points: 141
Snoc garden light not working
I have seven Snoc lights in the garden. They take a MR16 bulb 20W 12V halogen bulb (same as my kitchen ceiling) and plug into a standard 120v electrical receptacle. A new bulb didn't work in the Snoc socket (the bulb was good as I put it somewhere else on the circuit and it worked). Is there a way I can use a multimeter to troubleshoot the socket wiring seeing as how it's not the bulb that is at fault?
RocketGal is offline   Reply With Quote
Old 07-29-2012, 04:15 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Where is the transformer? At each head or one in the beginning of the circuit?
Old 07-29-2012, 04:22 PM   #3
Rewards Points: 141
on the wall
It's on the wall (exterior) near the outlet.
Old 07-29-2012, 07:16 PM   #4
E2 Electrician
Im not familiar with these lights, but are they daisy chained together or do you you run them back as home runs?
Im guessing the socket failed by the way... MR-16s run hot, and If the connections are not solid, they self detsruct.
Old 07-29-2012, 08:29 PM   #5
Rewards Points: 141
One thing ruled out
More info: The transformer that runs this circuit, with the failing light,has 2 other successfully lit lights. So, i'm thinking the socket or the line somewhere has failed. I
wonder can I detect the source of the problem with my multimeter?
Old 07-29-2012, 08:31 PM   #6
E2 Electrician
just check for power at the socket, if thats a no go, then follow the wire back looking for the damaged section or bad splice.
Old 07-29-2012, 09:02 PM   #7
Rewards Points: 141
power check at socket
would i look for 12 v at the socket (seeing as how presumably the transformer takes 120v and takes it down to 12 v AC?
Old 07-29-2012, 09:24 PM   #8
E2 Electrician
Yep, that's it.
Freezer light not working bucksone Appliances 6 04-07-2016 12:48 AM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
Ceiling Fan Light Quit Working me_tank Electrical 3 12-22-2011 07:38 AM
Light switches stopped working HALLJ12 Electrical 2 11-06-2011 03:50 AM
Outside power outlets (three of them) and front yard light not working Davekebe Electrical 3 10-30-2011 04:07 PM
