Snaking 100 Ft In Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 04:34 PM   #1
Smile
snaking 100 ft in ceiling
I live in a 5 unit single story condo in Florida. I want to run 100ft of 12 /2 cable in a coomon low attic. This is a flat roof with roughly 3 ft high roof truss support. This will end as outlet for a golf cart.
Almost impossible to drag this wire along, How can i get this 100ft to the outlet? Yes it will cross over the other 4 units.
joebos is offline   Reply With Quote
Old 04-28-2012, 04:38 PM   #2
Rewards Points: 14,026
Any way to run it under the house? If not then go under ground.
Old 04-28-2012, 04:43 PM   #3
Pure Genius
Rewards Points: 150
This might sound crazy but ive seen guys use rc trucks before
Dierte is offline   Reply With Quote
The Following 2 Users Say Thank You to Dierte For This Useful Post:
a_lost_shadow (04-29-2012), Ravenworks (04-28-2012)
Old 04-28-2012, 04:49 PM   #4
Yup sounds crazy, how is a car going to climb up and over the ceiling joist?
Old 04-28-2012, 04:51 PM   #5
Electrical Contractor
kbsparky's Avatar
Bow and arrow, with kite string attached. Shoot across the ceiling, then pull heavier rope, then pull wire.
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
a_lost_shadow (04-29-2012), goosebarry (04-28-2012), Ravenworks (04-28-2012)
Old 04-28-2012, 05:47 PM   #6
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Use conduit gluing as you go slide a piece up there then glue it and keep repeating this till you get to the other end. Then run the contuit in the walls and to where you need it. Fish the wires through the conduit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-28-2012, 05:57 PM   #7
liscenced electrician
Rewards Points: 538
Agreed. May have the build something the keep the end facing up
jimmy21 is offline   Reply With Quote
Old 04-28-2012, 07:20 PM   #8
rrolleston's Avatar
Reducing coupling glued on the end and just cut it off when you get to the other end.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
