Smurf Tubing - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 08:54 PM   #1
Smurf tubing
i have a empty 3/4 inch blue smurf tube that i want to use to go to a J box and supply a instant hot water heater which requires 8ga and a AC unit that requires 10ga both 230volt, will all the wires fit in the 3/4 inch tube ?? and is it ok to run the 3/4 tube to a junction box and then go to the 2 different units ?
wwkorn is offline   Reply With Quote
Old 02-04-2013, 09:56 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by wwkorn View Post
i have a empty 1 inch blue smurf tube that i want to use to go to a J box and supply a instant hot water heater which requires 8ga and a AC unit that requires 10ga both 230volt, will all the wires fit in the 1 inch tube ??
2 #8's and 2#10's (+ ground) will fit in 1" ENT with room to spare.
Old 02-04-2013, 09:58 PM   #3
change in size
i just revised my post , i have 3/4 not 1 inch
Old 02-05-2013, 06:30 AM   #4
Rewards Points: 776
Isn't smurf tube for comms circuits cat5 and RG6?
curiousB is offline   Reply With Quote
Old 02-05-2013, 12:26 PM   #5
Rewards Points: 332
In some areas, it is allowed for line voltage.
sgip2000 is offline   Reply With Quote
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 07:47 PM
Buried Copper LP Tubing Earnie Plumbing 1 02-22-2011 09:22 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
How tight for Poly tubing? Ultrarunner2017 Plumbing 4 03-26-2009 08:41 AM
ENT (Smurf) feeding a sub in detached garage) jamiedolan Electrical 1 02-02-2009 01:52 PM
