Old 11-18-2008, 12:02 PM   #1
DIY'er
jamiedolan's Avatar
SMURF to EMT
Is there a approved method of connecting the blue SMURF tube to EMT without using a junction box?
I have a spot where it would be useful to be able to transition to smurf, but the location will not be accessable so I can't put a pull box there.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-18-2008, 01:02 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
SMURF to EMT
Yep carlon is one brand they look like this and are called transition adapters. I had to go to the carlon site to find out cause I never use the stuff....
Old 11-18-2008, 03:07 PM   #3
DIY'er
jamiedolan's Avatar
SMURF to EMT
Thanks. I should have been smart enough to look at there web site.
I just used a piece of the smurf tube for a 12 foot run between the joists and into the crawl space, would have taken me well over a hour to get emt into that space. I am only using smurf in areas that are conceled / protected from damage, everything exposed is in EMT. Smurf still seems much better than romex. And I really like THHN, so much easier to work with than NM.
Why don't you ever use smurf?
Jamie
Old 11-18-2008, 03:22 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
SMURF to EMT
I just don't like the stuff over other wiring methods. It has to many restrictions when exposed. And I don't like the color......
Old 11-18-2008, 05:43 PM   #5
Electrician
SMURF to EMT
Smurf tube(never heard it called that until i saw it on this board) has it uses. it is very handy when you have to run stuff in a poured concrete floor.
I was just going to remind you to pull a ground in the smurf, you probably know that but it is easy to forget epescially when it is mixed in with EMT.
darren is offline   Reply With Quote
Old 11-19-2008, 12:03 AM   #6
DIY'er
jamiedolan's Avatar
SMURF to EMT
It's may be redundant, but I have been pulling a green 12 gage ground with everything I do. Even thought my EMT is really well put together and I am sure it serves will as a grounding path. Several people here recomended that I pull a ground to reduce the risk of arcing to conduit in the event of a fault.
Jamie
My local AHJ on Smurf Gigs Electrical 3 11-12-2008 04:35 AM
