Smoking 240v Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 02:37 AM   #1
Angry
smoking 240v outlet
Hi, I just moved into a house and was told I needed to add a cover plate over the 4-wire 240v dryer recepticle. The standard Home Depot cover plates were too small to fit over the recepticle head so i decided to replace the recepticle with a smaller headed version that my cover plate would fit over. So i took the old one out and replaced with the new one and turned the breaker back on (dryer not plugged) and the outlet started smoking. I immediately turned it off again and checked my wiring, which was Red and Black to X and Y respectively. White to the "L" shaped terminal (bottom) and bare copper ground wire to the ground/circular terminal.
Anyone know why it would start to smoke? I didnt do any readings on the voltage as i just made sure i out things back like the way they were.
Julian
julianhaigh is offline   Reply With Quote
Old 09-02-2010, 05:46 AM   #2
Electrical Contractor
kbsparky's Avatar
Excessive moisture, or other foreign substance may have been present inside of that receptacle.
I'd take it back to the home-horror store, and tell `em you want a replacement from the non-smoking section ....
If you are near an electrical supply house, see if they have a Mulberry 97225 cover plate. That one should fit your old receptacle.
-KB
Old 09-02-2010, 08:15 AM   #3
Licensed electrician
Rewards Points: 1,478
Sounds like the correct receptacle was already installed but you purchased the wrong cover plate. Like KB said, the correct trim plate is available.
Old 09-02-2010, 12:40 PM   #4
Thanks. However I turned the breaker off again and took off the cover plate and pulled out the receptacle such that it was just dangling out of the electrical box. I turned the breaker back on and it did not smoke. This kinda rules out the receptacle as being bad and also my concern that maybe there was some un-stripped wire insulation in the screw fastener that was burning up.
There is a fair amount of debris in the electrical box, i wonder if it was this that was smoking rather than the receptacle...?
Also, does it matter if the 4 wires going into the receptacle are touching each other when placed back into the electrical box......?
Julian
Old 09-02-2010, 02:43 PM   #5
Insulated wires contacting each other in the box should not be a problem.
Old 09-02-2010, 03:53 PM   #6
OK, thanks. So I guess I will clean out the debris and screw the receptacle back in and screw the cover plate back on and turn on the power again and see what happens.
Julian
Tags
240v , 4 wire , dryer outlet , fire , receptacle
Strange 240v outlet BearcatBengal Electrical 30 03-02-2010 11:10 PM
240v 3 prong outlet ISSUES!! JanosX Electrical 4 12-05-2009 01:00 PM
Pulling 120V outlet from a 240V circuit? npage148 Electrical 12 11-08-2009 11:29 AM
240V Kiln Outlet to Air Conditioner Outlet artman Electrical 8 06-29-2008 06:21 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
