Smoke, Sparks And Pops From Ceiling Fan - Need Assistance On Proper Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 07:41 AM   #16
Learning by Doing
Leah Frances's Avatar
Originally Posted by oh'mike
Leah--The wisdom of the wise is an uncommon degree of common sense.-----
----Mike-----
Thnxs, Mike.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-17-2011, 08:26 AM   #17
I=E/R
a7ecorsair's Avatar
In the drawing, are you sure A doesn't go back to cable #1? The wiring appears to be old romex with the exception of the newer romex that was tapped into the circuit.
Each cable should have a white and black wire.
By the number of wires connected to B I'd say it is a hot feed and C is a collection of neutrals.
Since there is a switch that affects this, A must be the switch feed or part of a switch leg. Take another close look inside the ceiling box and verify the wiring.
a7ecorsair is offline   Reply With Quote
