-   -   Smoke Detectors for Bedroom (http://www.diychatroom.com/f18/smoke-detectors-bedroom-52944/)
cibula11 09-13-2009 08:05 PM
We are converting a garage to a bedroom and need the smoke detectors hardwired. We live in an older home and have smoke detectors in every bedroom, but they are battery operated. Will ALL detectors need to be hardwired or just the one for the remodel?
kbsparky 09-13-2009 08:16 PM
This depends on where you live. Some areas are requiring all smokes to be hard-wired and interconnected. Others only require upgrades to hard wired status.
Still others do not require diddly-sqwat.
What does your building permit and inspection office have to say?
Scuba_Dave 09-13-2009 08:30 PM
Up to the local Fire Inspector is my understanding
Here any large renovation/addition (25% of house usually) & they require all smokes to be hard wired
vsheetz 09-13-2009 11:46 PM
As others have said you need to check your local requirements. I recently remoded and was ok with one hardwared (with battery backup) in the bedrooms area hallway, bedrooms and others ok battery powered, and all communicated (wirelessly).
Termite 09-14-2009 12:21 AM
Totally up to the jurisdiction. The code does require harwired smokes, but that shouldn't mean that you should have to pull wire in parts of your home that are existing and unaffected by the scope of the remodel. The code also makes provisions for allowing battery operated smokes when pulling wire to interlace the smokes would be impossible or impractical.
My stance...
If you're working in a room that has attic accessible above, for example, then it is a no brainer to have the smoke in the room and the one outside the room interlaced. If you're working upstairs it would be out of line (in my opinion) to require you to bring the remainder of the house's smokes up to current code.
