Smoke Detectors - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 12:57 PM   #1
Smoke detectors
Do I need two smoke detectors in a room that has a ceiling height change of more then 24"
Danworthington is offline   Reply With Quote
Old 08-04-2010, 01:00 PM   #2
I've never heard of 2 being required in a room
What type of room ?
Where are you located ?
1 is required in each bedroom, one on each level of the house
Hard wired now required almost every where I think
Old 08-04-2010, 09:15 PM   #3
Table32-1
Smoke alarm requirements
Location Requirement Circuitry
All floor levels Smoke alarms must be installed on each floor
level, including basements, 900 mm or more
above or below an adjacent floor level. Each
bedroom must be protected by a smoke
alarm either in the bedroom or outside. If
outside the bedroom, it must be installed
within 5 m of a bedroom door. This
measurement should be made along the
corridors and through the bedroom door, not
through walls or openings in walls.
The maximum distance between smoke
alarms on the same floor in rooms other than
bedrooms is 15 m. This measurement should
be made following corridors and going
through doorways, not through walls or
openings in walls.
Smoke alarms must be installed on the ceiling
or near the ceiling.
(See Article 9.10.19.2 of the NBCC.)
Smoke alarms may be installed in any lighting
and receptacle branch circuit, except for circuits
that supply kitchen counter and dining area
receptacles, refrigerators, outlets in a garage,
andoutdoor receptacles (see Rules26-720 to
26-724).
Smoke alarms must not be connected to
circuits that are protected by an AFCI or GFCI
or to circuits that supply only receptacles [see
Rule32-110(a)(ii)].
No switches or disconnecting means are allowed
to be installed between the smoke alarm(s) and
the overcurrent device for the branch circuit (see
Article 9.10.19.3 of the NBCC).
When more than one smoke alarm is required,
alarms must be interconnected so that the
actuation of one alarm causes all the alarms
inthe dwelling unit to sound (see
Article9.10.19.4 of the NBCC).
Battery backup is recommended.
macdonald is offline   Reply With Quote
Smoke and Carbon Monoxide Detectors user1007 Safety 1 01-14-2010 12:59 PM
Smoke Detectors for Bedroom cibula11 Electrical 4 09-14-2009 01:21 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
Smoke Detectors / CO Detector Bocolo Electrical 9 02-17-2009 06:12 AM
Wired Smoke Detectors? bjstewa Electrical 2 05-09-2007 09:20 AM
