Old 01-29-2012, 03:20 AM   #1
Smoke Detector Wiring.
As a part of my basement renovation I am installing Hardwired smoke detectors. I'd like to know can I tap the signal line of one sd to feed multiple others? In other words instead of going sd to sd, can I connect the signal lines of two upstairs sd's to the last one downstairs?
Mikenra is offline   Reply With Quote
Old 01-29-2012, 05:08 AM   #2
Julius793's Avatar
If I'm understanding you correctly there is no difference where you tap as long as they are all connected together.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-29-2012, 07:55 AM   #3
You need to run 14/3 (minimum depending on what size conductor is feeding them) from one sd to the next. The red wire will be hooked up as the signal wire from one to the next
heartlessmcfly is offline   Reply With Quote
Smoke detectors and reaction time Red Squirrel Safety 6 02-24-2012 01:12 AM
Smoke from Initial Fire-off Jaylie HVAC 10 11-21-2011 02:01 AM
Questions on installing Smoke Detectors danielrg Electrical 10 08-30-2011 01:08 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
