Old 10-12-2010, 11:17 PM   #1
smoke detector required
If a new house is being wired by an alarm company and they are installing smoke detectors, do I still have to hard wire them in addition to this?
wayneo is offline   Reply With Quote
Old 10-12-2010, 11:34 PM   #2
Depends on what the AHJ says. Around where I am we always put them in and the Alarm company ones are optional. Sometimes the alarm company can put in a relay to work with you electrical smokes. They need to be brk smokes i am pretty sure. As long as all the smokes are interconnected the alarm company should be able to install the relay which saves you on buying 2 sets of detectors. So now your hardwired smokes are now part of your alarm system.
Chevyman30571 is offline   Reply With Quote
Old 10-13-2010, 07:05 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Not typically.
Usually, if you have a central station monitored system with heat/smoke/CO detectors then 120v detectors are not required.
Smoke detector in garage? BlueBSH Electrical 6 03-18-2010 03:57 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
Masons: Smoke Shelf removal? BarryKaraoke HVAC 4 01-12-2008 07:31 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
