Smoke Detector Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 11:45 AM   #1
Rewards Points: 278
smoke detector question
My home is built in 1990, I found this one smoke detector it has a very faint grow in the LED upstairs hallway.
I thought it was installed by the alarm company, but I couldn't find any wires going into the alarm, or power going to it from the alarm panel. Does it look like the builder's or the alarm companies?
Can someone tell me more about it, is it hardwired with 120VAC?
DIYGST is offline   Reply With Quote
Old 06-07-2013, 11:47 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Looks like an old 120V battery backup unit.
I'd replace them all. They DO have a finite life.
Old 06-07-2013, 12:03 PM   #3
Rewards Points: 278
Hi, would this be a direct replacement?
http://www.homedepot.com/p/t/2035240...atalogId=10053
Attic access needed?
Old 06-07-2013, 12:07 PM   #4
Yup. So is this: http://www.homedepot.com/p/t/1000658...N#.UbIEjJzfLQw
Any SD that is 120V and battery back up will work. Personally I'd also replace one with one that is a combo SD/CO detector.
No attic access is needed. They are replaced like any light fixture. Should just be a wire-for-wire swap. Most times the red wire in the ceiling is your interconnect wire, which on the smoke is typically a yellow. Other than that it is black/black, white/white.
Old 06-07-2013, 12:09 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Pretty direct replacement... the top will snap off... sometimes a pin to remove... get a ladder and look around its edges..(EDIT: Oh it says, twist to remeove...duh)
Most replacements will have the capability to wire as a single unit, or feeding any other alarms on your system to go off on any alarms alert.
The wires are color coded, and explained in the directions.
MTN REMODEL LLC is offline   Reply With Quote
Change your clocks, AND Your Smoke Alarm Batteries!! Firefighter3244 General DIY Discussions 10 03-10-2013 07:19 PM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 06:03 AM
adding new wired smoke detectors to existing wired smoke detectors CapeCod153 Electrical 9 06-21-2012 06:03 AM
Smoke from Initial Fire-off Jaylie HVAC 10 11-21-2011 02:01 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
