-   -   smoke detector question (http://www.diychatroom.com/f18/smoke-detector-question-181442/)
DIYGST 06-07-2013 10:45 AM
1 Attachment(s)
My home is built in 1990, I found this one smoke detector it has a very faint grow in the LED upstairs hallway.
I thought it was installed by the alarm company, but I couldn't find any wires going into the alarm, or power going to it from the alarm panel. Does it look like the builder's or the alarm companies?
Can someone tell me more about it, is it hardwired with 120VAC?
Speedy Petey 06-07-2013 10:47 AM
Looks like an old 120V battery backup unit.
I'd replace them all. They DO have a finite life.
DIYGST 06-07-2013 11:03 AM
Hi, would this be a direct replacement?
http://www.homedepot.com/p/t/2035240...atalogId=10053
Attic access needed?
Speedy Petey 06-07-2013 11:07 AM
Yup. So is this: http://www.homedepot.com/p/t/1000658...N#.UbIEjJzfLQw
Any SD that is 120V and battery back up will work. Personally I'd also replace one with one that is a combo SD/CO detector.
No attic access is needed. They are replaced like any light fixture. Should just be a wire-for-wire swap. Most times the red wire in the ceiling is your interconnect wire, which on the smoke is typically a yellow. Other than that it is black/black, white/white.
MTN REMODEL LLC 06-07-2013 11:09 AM
Pretty direct replacement... the top will snap off... sometimes a pin to remove... get a ladder and look around its edges..(EDIT: Oh it says, twist to remeove...duh)
Most replacements will have the capability to wire as a single unit, or feeding any other alarms on your system to go off on any alarms alert.
The wires are color coded, and explained in the directions.
