Smoke Detector Position - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2012, 01:14 PM   #1
Rewards Points: 1,062
Question
smoke detector position
are smoke detectors any less effective when they are positioned high on a wall than when they are on the ceiling?
Old 03-24-2012, 01:17 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Generally you would want them at the highest point in the room. That is where the smoke is going to go, but if they are all flat ceilings, the code around here is that they have to be installed on the ceiling or within 1' of the ceiling.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
amakarevic (03-24-2012), zappa (03-24-2012)
Old 03-24-2012, 01:44 PM   #3
definitely within a foot. but i was thinking more because of the detector facing sideways rather than down
Old 03-24-2012, 01:50 PM   #4
k_buz's Avatar
Valid question but if you think about it, if there was smoke/fire it would be unlikely that it would originate directly under the detector. The smoke would rise to the ceiling, then spread out either completely engulfing the ceiling mounted detector or entering the detector from the side.
If it was mounted to the wall, the smoke would spread either engulfing it or entering from the face, top, bottom, or sides. Really no difference.
If you are still unsure read the booklet that comes with the detector. Some may have restrictions, but I haven't run into them.
The Following User Says Thank You to k_buz For This Useful Post:
Old 03-24-2012, 03:10 PM   #5
Master Electrician
Rewards Points: 3,874
Locate then away from return air registers as well.
brric is online now   Reply With Quote
Old 03-24-2012, 03:26 PM   #6
i don't have central AC in my house but thanks anyway. makes sense
Old 03-24-2012, 03:39 PM   #7
Rack em :)
NetTractorTalk's Avatar
I had an extra one and had none mounted in the kitchen at the time. I set it on top of the kitchen cabinets. Worked fine there. It would go off even before we saw any smoke. Wife used it as a way to tell when something was done. LOL Just kidding!!!!!! But it was easy to move to another location when it did go off due to the oven putting out a little smoke. Kinda handy.
NetTractorTalk is offline   Reply With Quote
Tags
smoke detector
Smoke detectors and reaction time Red Squirrel Safety 4 02-23-2012 08:15 PM
Smoke from Initial Fire-off Jaylie HVAC 10 11-21-2011 01:01 AM
Questions on installing Smoke Detectors danielrg Electrical 10 08-30-2011 12:08 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 08:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
