Smoke Detector Location - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 09:42 AM   #1
Send a message via AIM to Rich Send a message via Yahoo to Rich
Renovating a 160 year old home and updating all the electrical so required to add interconnected/hardwired/battery backup smoke detectors. Code says I need smoke in each bedroom and outside sleeping area. For the floorplan below I know I would need one in each of the 4 bedrooms. Would I need one on each stair landing and the sitting room or would just the main landing suffice? The ceiling height is 11 ft. (if it plays into this at all). Any thoughts would be appreciated.
Thanks.
Rich is offline   Reply With Quote
Old 03-28-2013, 10:05 AM   #2
Master Electrician
Rewards Points: 3,964
Thanks.
Every bedroom, within 15' outside the bedrooms, every level of the house, including a basement if applicable. Try to avoid smokes too near the kitchen.
In your case, both upper landings because they are divided by doors and probably the lower landings as well. Not needed in sitting room, although it would not hurt since there is a fireplace. We are required to place them at least 3' from any return air registers.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Rich (03-28-2013)
Old 03-28-2013, 10:24 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
You don't need CO detectors? I had to install CO's outside any combustion source....in the case of the hallway for 2 of the bedrooms...I used a combination CO/smoke.
Make sure you follow the instructions on placement....don't get them too close to the wall.
Old 03-28-2013, 10:50 AM   #4
Rewards Points: 1,016
Wireless not an option in your area? I installed them when doing whole-house remodel a few years ago. Work great. Also allows to easily have one in my detached workshop building.
____________
Vince
Old 03-28-2013, 11:10 AM   #5
Per 2009 IRC the one in the Hallway(s) would be combo units. Mainly trying to figure how many boxes I need to wire in. So as brric recommended one in each hallway do they both need to be combo units?
Old 03-28-2013, 11:16 AM   #6
Per the code if the renovation/remodel is opening ceilings/walls etc so that wiring is accessible they need to be hardwired/interconnected. I actually am moving a monitored wireless interconnected system from our previous home so the hardwireds are only being installed for purposes of inspection.
Old 03-28-2013, 11:18 AM   #7
JOATMON
ddawg16's Avatar
I think you only need the CO's where there is a source of combustion in the same general area/floor.
Old 03-28-2013, 11:30 AM   #8
Rewards Points: 320
Around here it is inside of every bedroom (new construction, or a major renovation of the existing residence), and within 10 feet of the entrance to any sleeping area, as well as a CO on every habitable level of the residence. Also we are now required to use combination photoelectric/ionization types in every required location except within 20 feet of the entrance to a kitchen or a bathroom with a shower. For those locations a photoelectric only type is required.
I think you will need to check your local authority having jurisdiction and find out exactly what is required in your area.
teamo is offline   Reply With Quote
Change your clocks, AND Your Smoke Alarm Batteries!! Firefighter3244 General DIY Discussions 10 03-10-2013 06:19 PM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Smoke detectors and reaction time Red Squirrel Safety 4 02-23-2012 08:15 PM
Smoke from Initial Fire-off Jaylie HVAC 10 11-21-2011 01:01 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
