Old 12-11-2010, 09:50 AM   #1
Smoke detector on light circuit...???
We're re-doing our basement and don't know much about electrical at all.... we ran a string of pot-lights, and have a hardwired smoke detector in the circuit as well. We were thrilled when we got them all installed, flipped the switch, and everything turned on..... until we realized that our smoke detector is only on when the light switch is on.
What have we done wrong? How do we fix it? (Unfortunately, drywall is done as well, and re-wiring the whole thing is going to be a pain... is there an easy fix?).... the smoke detector is in the middle of the circuit, is this the problem??
Thanks for any help.
Amy
blynn16 is offline   Reply With Quote
Old 12-11-2010, 11:27 AM   #2
Licensed electrician
You are going to need to find a circuit that is hot all the time. This sounds like it is going to require some rewiring.
If you have other smokes in the house the new ones should be on the same circuit as the others.
Old 12-11-2010, 12:00 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Amy
Having a clue BEFORE you started, and especially before sheetrock went up, would have been a great place to start.
My opinion? Call in a professional before you burn your house down. I can just imagine what the splice boxes look like.
Old 12-11-2010, 12:35 PM   #4
the Musigician
DangerMouse's Avatar
It sounds to me like you simply put the hot for the smokers on the wrong wire in the JB.
It needs to go to the incoming hot before the switch, not after.
This SHOULD be an easy fix.... if easy access is provided to the box.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 12-11-2010, 12:57 PM   #5
RST
DIY Homeowner
Sorry, no good news from me either. You may need to retroactively pull some permits too. Otherwise could have problems when you go to sell your house.
RST is offline   Reply With Quote
Old 12-11-2010, 01:10 PM   #6
the Musigician
Well, of COURSE they pulled permits!
They just want it wired correctly for the rough-in.... right? RIGHT???
DM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Bathroom light on a gfi circuit Debbo Electrical 1 04-28-2010 10:32 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Can a GFCI protected light be installed into a normal light circuit? boongywoongy Electrical 6 05-19-2008 09:02 PM
