Smoke Detector In Garage? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 07:24 AM   #1
Rewards Points: 640
Smoke detector in garage?
I am working on starting to install a hardwired CO / Smoke detector system... one CO / Smoke combination detector in each floor... with a smoke detector in all bedrooms and living spaces (living room, office, etc) all these are interconnected... but then I was trying to figure out if the finished garage should have a smoke detector or not... some places say no, but what if a car caught on fire somehow? Should I include one there in the plan? thanks
BlueBSH is offline   Reply With Quote
Old 03-16-2010, 07:34 AM   #2
Garage not required
I'm not sure what type you could install that would not get false trips
Hallways on each floor also require one
Old 03-16-2010, 07:45 AM   #3
Licensed electrician
Rewards Points: 1,470
Leaving the car running on a winter morning will set the alarm off from the exhaust. If you read the instructions with the alarms you will also see that most say not to install in garages or where the temperatures drop.
A better solution is a heat detector.
Old 03-16-2010, 07:50 AM   #4
Rewards Points: 640
Do they make interconnected heat detectors that can connect to smoke detector networks? I've never seen one at lowes before, so not sure what to look for
Old 03-16-2010, 10:02 AM   #5
The notes I got back with my building permit indicated I HAD to add a heat detector for the garage.
However, I've always had a smoke detector in the garage as well... but then again my garage is actually a part of the basement, so I don't want to keep the car running with doors closed.
HooKooDooKu is offline   Reply With Quote
Old 03-18-2010, 02:28 PM   #6
The heat detectors at my local lowes are listed as interconnected...but the name brand is something like "frenetics" and of course says it interconnects with other "frenetics" alarms.
Of course their web site indicates they carry a Kidde HEAT Alarm (interconnectable), but I've never seen it in the store.
Old 03-18-2010, 02:57 PM   #7
Rewards Points: 640
I have a similar situation, I can not find the Kidde heat alarms anywhere inside lowes, but their site says buy online pick up in store in 30 minutes for that specific item.....
Tags
garage , interconnected , smoke detector
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 09:22 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
