Smoke Detector False Alarm - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 09:34 AM   #1
Smoke detector false alarm
Last night at 3AM, we were woken up by our smoke detectors going off. We have a system where the detectors are hardwired together and each has a battery backup. The result is that when one unit reports smoke, the whole house screams at like 120 dB, which is not a great way to wake up...
No smoke, no fire, so we went around and started pulling the detectors. When I got to one of them and pulled it, the alarm stopped. I plugged the rest of them back in, and the alarm stayed off.
My thinking is that this 1 unit has a short in it. If it had been going off because of a blocked sensor or dust or something, it should have kept going off when I unplugged it from the system, right? I checked the battery, and it was fine.
I can't find anything online about a similar problem. Anyone here hear of anything like this?
shazaam42 is offline   Reply With Quote
Old 07-21-2013, 09:38 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If they are over 10 years old, they should all be replaced...not the batteries, the units themselves.
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (07-21-2013)
Old 07-21-2013, 10:47 AM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
look at the smoke that you pulled off on the back there is a DATE .....
or that one just took a SH!T
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 07-21-2013, 02:11 PM   #4
Rewards Points: 6,652
Shorts blow breakers, or cause batteries to explode. No, what you have is a unit going bad. It could be that breaking the connection on the plug cleaned the contacts, and removed a little bit of corrosion, is why it stopped, when you reset them.
Until you come back Shazamm42, all we can guess at this point what was going on.
Old 07-21-2013, 04:34 PM   #5
Rewards Points: 3,130
Same thing has happened to me, and our smoke detectors are only three years old. Could be something as simple as dust or spider webs.
Old 07-21-2013, 09:20 PM   #6
I'll check the date, but I'm probably going to just replace it anyway. I really think it just crapped out.
Thanks all!
Old 07-22-2013, 07:29 AM   #7
Rewards Points: 2,638
Same thing just happened to me. Mine went off at 5:00 AM, not 3:00, and the alarm stopped after about 5 seconds. I know my smoke detectors are old, and replacing them was already on my list of things to do.
I expect we have all managed to set off the smoke alarm while (over) cooking something in the kitchen, but I never even heard about false SD alarms (with zero smoke or humidity present) until I read your thread.
SPS-1 is offline   Reply With Quote
Old 07-22-2013, 07:40 AM   #8
When you change them out shazaam42, change them to Photo-Electric units, and also combo with CO detection for the bedrooms. You can at this point because they are faulty, use battery only units, which you can get for less than $10 at Lowe's, Ace Hardware, Home Depot, etc, until you can get the Photo-Electric cell units.
The ones I am talking about, have a shorter response time, then the older conventional ones, which can take up to a 1/2 hour to warn you, the Photo cells, can take less than 15 min's depending on the model to tell you that there is a problem. Also for bedrooms, get the ones that actually have a voice alarm, not the old school annunciator. Keep those for out in the other parts of the house.
Tags
false alarm , short circuit , smoke alarms , smoke detector , wiring
Change your clocks, AND Your Smoke Alarm Batteries!! Firefighter3244 General DIY Discussions 10 03-10-2013 06:19 PM
Smoke Alarm Under Drywall Detr1 General DIY Discussions 18 01-28-2013 07:47 AM
Kidde Smoke Alarm Battery Replacement e-Andy Electrical 0 12-29-2011 12:32 PM
Hard wired smoke alarm in NYS ADKstorm Electrical 12 04-30-2009 09:58 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 02:41 PM
