Smoke Detector Ceiling Position - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2013, 11:46 PM   #1
Rewards Points: 1,062
Smoke detector ceiling position
Does it matter where on a ceiling the smoke detector is or can it be anywhere?
Old 05-20-2013, 12:13 AM   #2
" Euro " electrician
frenchelectrican's Avatar
la plupart des cas à peu près partout, mais garder environ 12 pouces du bord du mur.
(most case almost anywhere but keep it about 12 inches from the edge of the wall.)
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
amakarevic (05-20-2013)
Old 05-20-2013, 12:18 AM   #3
can it be more than 12" from the edge of the wall (like in the middle of the ceiling) ?
Old 05-20-2013, 12:26 AM   #4
Sûr qu'il fonctionne très bien au centre ainsi., C'est un bon endroit aussi.
(Sure it will work just fine in the middle as well ., That is a good spot as well.)
Merci,
Marc
Old 05-20-2013, 12:29 AM   #5
Yes. FEMA says
Install smoke alarms on every level of your home, including the basement. Many fatal fires begin late at night or in the early morning. For extra safety, install smoke alarms both inside and outside sleeping areas. Since smoke and many deadly gases rise, installing your smoke alarms at the proper level will provide you with the earliest warning possible. Always follow the manufacturer’s installation instructions.
The NYC Dept. of Buildings seems to have improved on FEMA's instructions and included more detail.
Install smoke alarms on every level of your home, including the basement. Since many fatal fires begin late at night or in the early morning, install smoke alarms both inside and outside sleeping areas. Smoke and many deadly gases rise, so installing your smoke alarms on the ceiling will provide you with the earliest warning possible. Always follow the manufacturer’s installation instructions....Corner has dead air Space - do not place here....Distance from ceiling: At least four inches. Not more than twelve inches...
NEVER
�� Place a smoke alarm in or near a kitchen where it will go off too easily.
�� Place a smoke alarm in or near a moist place.
�� Place a smoke alarm directly in front of heating or cooling ducts.
�� Place a smoke alarm too close to windows, doors, ceiling fans where drafts could interfere with the detector’s operation.
Dorado is offline   Reply With Quote
The Following User Says Thank You to Dorado For This Useful Post:
mm11 (05-20-2013)
Old 05-20-2013, 12:44 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,192
When in doubt, read the instructions that came with the smoke detector. Mine say to keep the detector at least 6" from any wall.
Bonjour Marc. J'espère que vous allez bien. Je suis enclin à penser que notre affiche qui demande quesitons sur la modification de la fréquence du générateur ne dispose pas d'un diplôme en physique. Un exemple classique d'un troll. S'il avait un degré, il ne demandera pas le forum de bricolage pour les réponses.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
frenchelectrican (05-20-2013)
Old 05-20-2013, 11:45 PM   #7
Oui je suis d'accord avec vous que personne ne devrait utiliser le sens commun pour trouver la réponse à cette question.
Merci,
Marc
Change your clocks, AND Your Smoke Alarm Batteries!! Firefighter3244 General DIY Discussions 10 03-10-2013 07:19 PM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 06:03 AM
smoke detector position amakarevic Electrical 6 03-24-2012 04:39 PM
Smoke from Initial Fire-off Jaylie HVAC 10 11-21-2011 02:01 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
