-   -   Smoke detector ceiling position (http://www.diychatroom.com/f18/smoke-detector-ceiling-position-179990/)
amakarevic 05-19-2013 10:46 PM
Does it matter where on a ceiling the smoke detector is or can it be anywhere?
frenchelectrican 05-19-2013 11:13 PM
la plupart des cas à peu près partout, mais garder environ 12 pouces du bord du mur.
(most case almost anywhere but keep it about 12 inches from the edge of the wall.)
Merci,
Marc
amakarevic 05-19-2013 11:18 PM
can it be more than 12" from the edge of the wall (like in the middle of the ceiling) ?
frenchelectrican 05-19-2013 11:26 PM
Sûr qu'il fonctionne très bien au centre ainsi., C'est un bon endroit aussi.
(Sure it will work just fine in the middle as well ., That is a good spot as well.)
Merci,
Marc
Dorado 05-19-2013 11:29 PM
Yes. FEMA says
Install smoke alarms on every level of your home, including the basement. Many fatal fires begin late at night or in the early morning. For extra safety, install smoke alarms both inside and outside sleeping areas. Since smoke and many deadly gases rise, installing your smoke alarms at the proper level will provide you with the earliest warning possible. Always follow the manufacturer’s installation instructions.
The NYC Dept. of Buildings seems to have improved on FEMA's instructions and included more detail.
Install smoke alarms on every level of your home, including the basement. Since many fatal fires begin late at night or in the early morning, install smoke alarms both inside and outside sleeping areas. Smoke and many deadly gases rise, so installing your smoke alarms on the ceiling will provide you with the earliest warning possible. Always follow the manufacturer’s installation instructions....Corner has dead air Space - do not place here....Distance from ceiling: At least four inches. Not more than twelve inches...
NEVER
�� Place a smoke alarm in or near a kitchen where it will go off too easily.
�� Place a smoke alarm in or near a moist place.
�� Place a smoke alarm directly in front of heating or cooling ducts.
�� Place a smoke alarm too close to windows, doors, ceiling fans where drafts could interfere with the detector’s operation.
ddawg16 05-19-2013 11:44 PM
When in doubt, read the instructions that came with the smoke detector. Mine say to keep the detector at least 6" from any wall.
Bonjour Marc. J'espère que vous allez bien. Je suis enclin à penser que notre affiche qui demande quesitons sur la modification de la fréquence du générateur ne dispose pas d'un diplôme en physique. Un exemple classique d'un troll. S'il avait un degré, il ne demandera pas le forum de bricolage pour les réponses.
frenchelectrican 05-20-2013 10:45 PM
Oui je suis d'accord avec vous que personne ne devrait utiliser le sens commun pour trouver la réponse à cette question.
Merci,
Marc
