Smoke And CO Detector Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 03:04 PM   #1
Smoke and CO detector wiring.
I have installed a series of smoke alarms. I have all of them hooked up and the go off a the same time when testing them using battery backup power. I am now ready to hook the 14-3 wire into the panel, however, I am not sure where the red wire gets hooked up in the panel, or if it does at all.
johnmarkkrop is offline   Reply With Quote
Old 11-11-2011, 03:12 PM   #2
Electrician
Rewards Points: 760
Do you have these smoke detectors on a dedicated circuit, if you do make sure that is what your local codes say. If it was me(even if code said to put it on a dedicated circuit) I would put them on a circuit with some lights for you know if your breaker for the smoke detectors is off or tripped.
The red is only used as an interconnect between the smokes, the red would not get hooked up in the panel.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
johnmarkkrop (11-11-2011)
Old 11-11-2011, 03:18 PM   #3
Thank you Darren. I do have it on a circuit with some lights, although I didn't realize the benefit of know when the circuit may be tripped, just was more convenient. Thanks again for your help.
Old 11-11-2011, 04:07 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 816
I'll be wiring in some soon.....might be too late for you now....but only use 14/2 from the CB or light to the first detector. That way it's unlikly anyone tries to do something with the red wire....
If you do have the red wire hanging somewhere...wire nut it...and put a tag on it as to what it is.
ddawg16 is online now   Reply With Quote
Old 11-11-2011, 04:47 PM   #5
The wiring diagram which came with the detectors should show what is connected to power and what is used for the interconnect...
Billy_Bob is offline   Reply With Quote
Old 11-11-2011, 05:44 PM   #6
Electrician
Rewards Points: 760
Could always use the red for an extra circuit if you need it.
Questions on installing Smoke Detectors danielrg Electrical 10 08-30-2011 01:08 PM
White smoke after idling for about 20 minutes RedHelix Automotive Repairs 3 10-25-2010 08:28 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
Masons: Smoke Shelf removal? BarryKaraoke HVAC 4 01-12-2008 07:31 PM
