Smoke/Carbon Monixide Placement Code - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 03:13 PM   #16
Indications in the diagrams indicate location within 12" of the ceiling
As I recall my instructions indicated these exact details/locations
DOE link that seems to indicate that the CO will mix with Air & since they are close to the same density it is not critical
http://www.newton.dep.anl.gov/askasc.../chem03364.htm
But they do say:
Although the molecular weights of these gases differ, convection and not density differences dominate the distribution of CO, methane etc. The release of gases associated with combustion tend to rise because they are hotter than ambient. For this reason smoke detectors and CO detectors are usually placed high on the walls of hallways etc
Old 12-06-2009, 04:30 PM   #17
Chicago, IL
Michael Thomas's Avatar
To answer the OP's question: Most local codes incorporate NFPA 72, the "National Fire Alarm and Signaling Code."
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Code for Outlet Placement in Basement redbandit Electrical 5 01-02-2008 10:13 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
1950's Roof Framing Strength KempLN Building & Construction 21 06-17-2006 10:06 AM
