Smoke Alarms? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 07:04 PM   #1
smoke alarms?
Do smoke alarms have to be a certain distance from a door in a bedroom or within a certain distance of the door?
Railz is offline   Reply With Quote
Old 12-18-2008, 07:16 PM   #2
Electrician
Always read the manufactures instructions.
chris75 is offline   Reply With Quote
Old 12-18-2008, 07:24 PM   #3
Rewards Points: 862
Funny you should ask that question. I was just reading the manual for the ones I have, and it says that the detector should be placed in the center of the ceiling of the room, but if not practical, that it be mounted no closer than 100 mm (4 in.) to any wall or corner.
It also states that if local code allows for the detector to be mounted on a wall, that it be located between 100 mm and 300 mm (4 in. and 12 in.) from the wall/ceiling intersection.
Ours are the photoelectric type, but I don't think the type should make a difference for mounting.
Ultrarunner2017 is online now   Reply With Quote
Old 12-18-2008, 08:02 PM   #4
Registered User
Termite's Avatar
Definately the best advice. On an inspection, when looking at smoke detectors, that's the first thing I ask for.
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
AC Smoke alarms - Nuisance Alarms jamiedolan General DIY Discussions 8 10-27-2008 08:56 AM
Smoke Detector, Intermittent Chirping Rod Electrical 18 02-23-2008 07:46 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
12 Smoke Alarms sootybuttercup Electrical 8 09-19-2006 09:06 PM
