Smoke Alarms - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 11:14 PM   #1
Smoke Alarms
Is their a code that smoke alarms have to be on a dedicate breaker or they can go on any. also does a smoke alarm count as a circuit or not and you can wire them up to any 15 amp line.
POWER STROKE is offline   Reply With Quote
Old 01-11-2013, 11:26 PM   #2
Licensed electrician
Rewards Points: 1,276
Some locations like Delaware require a dedicated circuit. The NEC does not. Check with your building officials.
Smoke alarms are fine on a 15 amp circuit.
NJMarine (01-12-2013)
Old 01-11-2013, 11:32 PM   #3
Rewards Points: 6,652
Covered in 2006 dedicated circuit for smoke detectors
Old 01-11-2013, 11:35 PM   #4
joed's Avatar
Rewards Points: 12,016
Some locations require a non dedicated circuit so that you can tell if the breaker is tripped. In Ontario they must NOT be on the AFCI bedroom circuit.
Old 01-11-2013, 11:35 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
Common but good question.
For the most part, the smokes can go on any ckt....but, they can not have a switch to turn them off except for the breaker.
With that said....one good idea I got from this forum was to put them on one of the light ckts.....that way, your less likely to turn them off if they start to 'bother' you.
So...in my case...since I'm adding a bunch in my new addition...I put them on the laundry room lights...
Old 01-12-2013, 07:30 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Not in my location, but some areas require smokes to be on a bedroom circuit. Don't forget about CO detectors as well. There are "new" requirements concerning those as well. I would ask both these questions to your local building department.
Old 01-12-2013, 08:29 AM   #7
Rewards Points: 3,130
Smokes must also be wired so that if one goes off, they all do.
Kidde Smoke Alarms FALSE alarms DSmith1 Electrical 11 12-03-2015 12:38 AM
Wiring for residential smoke alarms under 2008 NEC jeffers Electrical 13 05-13-2010 10:51 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
AC Smoke alarms - Nuisance Alarms jamiedolan General DIY Discussions 8 10-27-2008 08:56 AM
12 Smoke Alarms sootybuttercup Electrical 8 09-19-2006 09:06 PM
