Smoke Alarm - Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2008, 02:19 PM   #1
smoke alarm - ground wire
I learned from you guys that smoke alarms should be replaced (app. 10 years), and since mine was 17 years old, I bought a bunch of dual sensor alarms.
The alarms are connected, and I started at the end of the run. No problem with the red, black, and white wires, but there is a ground wire in the box (plastic) that is not connected to anything. Is that all right?
As always, thank you for your help,
potomac101
Potomac101 is offline   Reply With Quote
Old 02-05-2008, 04:54 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
That's right.
Just twist 'em, wire nut 'em, and stick 'em in the back of the box.
Old 02-05-2008, 05:05 PM   #3
waiting for spring
arichard21's Avatar
Rewards Points: 150
Just curious, can you buy 14/3 w/o ground for alarms? it seems like a waste to have those ground wires there doing absolutly nothing.
arichard21 is offline   Reply With Quote
Old 02-05-2008, 10:01 PM   #4
Rewards Points: 1,448
I have never seen Romex type cables without ground for sale. Now if that was available, it would be such a low demand item that the price would be close to the price of cable with ground wire.
Who knows, someday they may invent smoke detectors that require grounding.
AllanJ is online now   Reply With Quote
Old 02-05-2008, 10:14 PM   #5
Rewards Points: 266
They do make such a thing:
WOG NM
junkcollector is offline   Reply With Quote
Old 02-06-2008, 07:45 AM   #6
waiting for spring
arichard21's Avatar
Rewards Points: 150
So, with that WOG NM, would it be acceptable to wire up a cct containing all the smokes for the house, starting at the panel and 14/2 WG to a light switch then to a light (that is commonly used in case the there is a problem you would know the smokes weren't working), then continuing on from the light with 14/3 WOG to the smokes?
The only issue I can think of is if it were ever to be spliced you would not be able to use a metal junction box because there would be no way to bond the box...
Old 02-06-2008, 08:12 AM   #7
WOG NM
"Amapcity of the product is limited to that for 60 degrees Celsius rated conductors per the National Electric Code Article 336."
Really? Art. 336 huh?
Sorry, that stuff would not be legal to install for most of us:
334.108 Equipment Grounding
In addition to the insulated conductors, the cable shall have an insulated or bare conductor for equipment grounding purposes only.
Handbook commentary:
Changed for the 2005 Code, this section no longer permits an equipment grounding conductor; it requires an equipment grounding conductor. The required equipment grounding conductor must be sized in accordance with 250.122 and comply with UL 719, Standard for Nonmetallic-Sheathed Cables.
Old 02-06-2008, 08:25 AM   #8
waiting for spring
arichard21's Avatar
Rewards Points: 150
Petey, but if there is nothing to ground it to... why would it be required?!?
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Hard wired smoke alarm in NYS ADKstorm Electrical 12 04-30-2009 10:58 PM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 09:23 AM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
