Smart Meters - Aluminum, Copper Wires Incompatible? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 06:04 AM   #1
Smart Meters - aluminum, copper wires incompatible?
So the local power company here in Houston (Centerpoint) sent out a guy to swap our house out to a smart meter yesterday. Only problem is... he couldn't do it.
Apparently the wire running to the house is copper, and the wiring in the house is aluminum (or vice versa?), and there's some "lug" in the analog one that allows this combination but the new smart meter isn't so forgiving.
Now I have to have the power line from the house to the box replaced, about a $4,000 project since the line is underground and a couple hundred feet of it will have to be replaced.
Does this sound right to anyone?
JSchool is offline   Reply With Quote
Old 11-15-2012, 06:22 AM   #2
Rewards Points: 1,214
Sounds like theres more to it than copper to aluminum issue at the meter. If they are telling you to replace the underground conductors they are probably failing.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Speedy Petey (11-15-2012)
Old 11-15-2012, 06:34 AM   #3
Okay I spoke to my girlfriend and got a bit more information (I didn't speak to the meter replacer myself). What you're saying might have something to do with it - apparently he measured low voltage in the line. But this is what the notice says that he left:
"Found a foreign clamp in the meter can splicing the line-side wire energizing the loadside lug. Wire needs to be replaced".
I have an electrical engineering background but I only work with low power devices, so I'm not quite sure what he means other than it sounds like the cable had been cut previously requiring a splice and the clamp doing so shouldn't be there because... they don't want it there? Apparently it used to be acceptable and now it's not so they won't replace the meter. Any of that sound right?
Old 11-15-2012, 06:38 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Sounds to me that the meter can is damaged and that when someone fixed it, they didn't use the correct AL/CU lug. Ultimately the POCO will tell you what you are required to do. If they say you have to replace the can, you are going to have to replace the can.
Old 11-15-2012, 06:48 AM   #5
Rewards Points: 3,256
Sounds like a bypass.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
Julius793 (11-16-2012)
Old 11-15-2012, 07:20 AM   #6
Rewards Points: 720
Yep. Sounds like someone was getting free juice. If this is the case, I'm surprised he didn't pull the meter until this was corrected.
Mark
busman is offline   Reply With Quote
Old 11-15-2012, 08:47 AM   #7
I wish I were getting free juice!
Okay apparently this is what is going on.
The line in coming from underground to the meter was too short so it was spliced (by the power company) some time ago. But the splice is making contact with something which is causing a voltage issue.
The power company wants to remove the splice because they don't allow that sort of solution anymore. But they say that the way to fix that is to run a whole new line out to their box in the back yard.
It's kind of bizarre because they did this to begin. This is all within their own locked box, yet I'm supposed to pay 4k to run a new line to it.
Seems like the meter could just be... moved lower. It's only a six inch splice. Assuming there's no degradation in the underground lines, would that not be a perfectly reasonable alternative?
Old 11-15-2012, 10:14 AM   #8
Rewards Points: 720
Around here, the PoCo will splice line side conductors in the meter can to save re-running the lateral. I've never seen them do it for a drop. They just replace the cable.
Mark
Old 11-15-2012, 08:27 PM   #9
tell them your not intereested in the smart meter or the cost associated with repairing it .they should foot tje bill
mrairflow is offline   Reply With Quote
Old 11-16-2012, 06:09 AM   #10
"Might as well talk to the wall"
Mid Roof Smart Vent and ice dams mbergm57 Roofing/Siding 5 10-14-2011 06:49 PM
GE Smart Timer in a 3 way switch vanisle Electrical 8 10-27-2010 01:34 AM
one service main two meters danadude1 Electrical 15 02-28-2010 01:17 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 08:45 AM
GE cl200 kwa meters protechplumbing Electrical 15 09-23-2008 12:10 AM
