Smaller Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 08:59 PM   #1
smaller ground
I have run into this small ground wire and I know this is not suitable for a good ground. I was just wondering if it is okay to just attach it to the ground screw or to just cap it or what? It looks it is the stage before romex because its not a plastic sheathing.
jmans8666 is offline   Reply With Quote
Old 08-01-2011, 09:19 PM   #2
I=E/R
a7ecorsair's Avatar
When ground wires first came into existence in romex cable the ground wire was one size smaller than the conductors. The cabin we tore down last summer had an electrical inspection sticker from 1961 and all the wiring had grounds one size less than the conductors. Most of the cabin was #14 romex with #16 ground. Use it as is and treat it like any ground wire.
a7ecorsair is offline   Reply With Quote
Old 08-01-2011, 09:41 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You just can't extend the circuit off it.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-01-2011, 11:07 PM   #4
Does anyone know why they make it smaller? Just curious
Old 08-02-2011, 07:47 AM   #5
I=E/R
a7ecorsair's Avatar
The smaller ground romex has been out of production for quite awhile - 40+ years, I'd guess. Current production cabling in 10, 12, and 14 have the ground the same sized as the conductors.
Remember, the ground is there for safety and in normal conditions has zero current flowing. On a dead short, it only has to handle current until the breaker trips.
Old 08-02-2011, 03:22 PM   #6
I know why its there and all but I meant like why was it made smaller back then
Old 08-02-2011, 04:35 PM   #7
Rewards Points: 6,652
Think about what was happening between the late 1930's and early 1950's really hard.
Old 08-02-2011, 05:05 PM   #8
I=E/R
a7ecorsair's Avatar
That's a pretty tough question.
Could have been:
Cost of materials
Probably felt that one size smaller was safe, which it is.
Didn't know any reason to make it equal.
Got along for years without a ground.
Old 08-02-2011, 05:12 PM   #9
Well as long as it works its good
Old 08-02-2011, 06:41 PM   #10
Rewards Points: 95
Umm, how much smaller is it?
My house is about 125 years old. What few grounds I've found seem to be iron wire about 1mm in diameter. Is that possible?
-Jeff
mysterylectric is offline   Reply With Quote
Old 08-02-2011, 06:47 PM   #11
Are you sure that it is not carbon wire? Iron would have corroded away a long time ago.
Old 08-02-2011, 08:34 PM   #12
Electrical Contractor
kbsparky's Avatar
Funny that in the US, a reduced ground was eliminated when the 1971 Code took effect.
But in Canada, romex (they call it "loomex") still has a reduced grounding conductor in it, and they have not burned down, nor experienced mass electrocutions up there.
-KB
Old 08-02-2011, 08:43 PM   #13
I=E/R
a7ecorsair's Avatar
Wow, you remember back that far
Maybe time for dessert
Old 08-02-2011, 09:13 PM   #14
Rewards Points: 95
Carbon wire? I'll definitely have to web search that one.
Well, steel wire, whatever, and maybe 2mm. Maybe copper or even nickel coated copper. But as I recall stiffer, and yeah it's rusting and busting up all over the place. Hence only 1 in 5 outlets are grounded. Kind of a big bummer. The electrical was upgraded in '76 with a bunch of new rigid runs and boxes in the basement, but few if any new circuits. I assumed for years they'd gone the last foot with NM or something. When I found the knob and tube stuff in the switchboxes I just figured they left the switch legs in the old wire. But when I started finding it in outlets on the first floor I got suspicious, sure enough I peeked up behind the boxes in the basement and they had left the last foot or three in the old wire, and didn't pull new grounds. That's ridiculous considering that even the K&T in my house was all retrofit and not nailed in. It's trivial to use the old wire to pull NM into place.
Old 08-02-2011, 10:05 PM   #15
Old houses, you never know what people use, especially if it was a old farm house. When we redid our bath, we found a nice taped up mess just stuffed into the wall cavity. Old trailer I bought from my sister, the person that wired the front light & heat tape outlet, used 16awg lamp wire from an extension cord. Carbon wire is really not made out of Carbon, it looks like that after it ages, due to the coating from the air getting to it over time.
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 05:10 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
