Old 01-17-2013, 07:24 PM   #1
small spring-wound timer switch for bath fan
I am looking for a spring-wound (non electronic) timer switch for residential exhaust fans. The trouble is that the box is the size that typically has 2 switches side-by-side or 4 standard (120V) outlets. This box has 4 of the smaller-type switches. Please don't suggest that I install a larger or another box. It is in a tiled bath and I don't have the skills or time to attack that. If I can't fid a way to do it in the existing box, it stays a simple switch. No neutral in the box.
Thanks for reading!
ionized is offline   Reply With Quote
Old 01-17-2013, 08:03 PM   #2
chitownken's Avatar
This what you are looking for? http://www.amazon.com/Woods-59717-De.../dp/B001XCWLX8
chitownken is offline   Reply With Quote
Old 01-18-2013, 12:45 AM   #3
Thanks, but it does not look like it. I have 4 toggle switches in a 2 gang box. I don't think I can fit this in wihout replacing the box in a tiled wall.
Old 01-18-2013, 09:21 AM   #4
One of these....
http://www.lifeandhome.com/3-single-...FQSg4Aod5icA1Q
and one of these.....
http://www.1000bulbs.com/product/3308/ELEC-FD30MWC.html
Make sure to check the box fill.
teamo is offline   Reply With Quote
Old 01-18-2013, 10:53 AM   #5
Thanks. That looks like it should work. I guess that Cooper's plate should work?
http://www.cooperindustries.com/cont...s_anp_d_15.pdf
Intermatic's information seems to indicate that they can be made to fit toggle or decorator style:
http://www.intermatic.com/en/Product...es/FD30MC.aspx
Box fill is something that I am aware of as a concept only. My understanding is that it is not dependent on, in this case, the switches that are used, only the cable or wire connections in the box. Please tell me if I am wrong. I also understand that even if box fill is not exceeded, I might still not be able to fit what I might want into a particular box.
If I am correct, in my case if the electrician that did the current installation did his job, I can change switches with abandon, as long as they fit.
Old 01-18-2013, 11:29 AM   #6
Special User
http://ecmweb.com/code-basics/box-fill-calculations
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-18-2013, 11:52 AM   #7
The Intermatic comes with a plate which fits the decora style plates or you could use it without the plate for toggle style plates. The switch is the decora style. Personally I think it looks better in a decora style plate so for this application you would need a double decora switch plate but that is up to you.
Old 01-18-2013, 12:26 PM   #8
Thanks, very much. I obviously remembered wrong about the fill. The yoke size is used in calculations but not the size of the switch itself. I knew that there was some disconnect between the ability to squeeze in a device and the box fill.
I agree, the Decora-style would be the way to go here.
220 wall heater wiring to a timed or spring switch zacman44 Electrical 0 11-28-2012 05:40 PM
Timer Switch Installation Guide iabros Electrical 0 11-16-2012 05:18 AM
Electronic timer switch loomiswa Electrical 1 02-07-2012 11:35 PM
Timer Switch Hookup Yankee1423 Electrical 6 02-05-2011 10:02 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
