Small Solar Disconnect Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 07:17 PM   #1
Question
small solar disconnect switches
If you have a small charge controller with an integrated disconnect swithc would you still need another disconnect? Where would you install this - on which wire (pos v neg) and in between which appliances? Why is this necessary?
Thanks!
rescrewableE is offline   Reply With Quote
Old 01-02-2010, 08:55 PM   #2
The following gives some code references and explanations...
http://www.xantrex.com/web/id/1661/docserve.aspx
Other than that, I would suggest asking your local electrical inspector what is required.
Billy_Bob is offline   Reply With Quote
Tags
disconnect
Help me ID these switches... jp2code Electrical 15 05-02-2015 09:52 PM
using solar power to run ac products. contin Electrical 5 01-02-2010 07:27 PM
Two Ceiling Light Fixture switches suddenly acting flakey!!! babalina Electrical 5 10-12-2009 08:52 PM
fused disconnect and/or GFCI ? pchiz Electrical 8 12-21-2007 11:02 AM
