Old 01-07-2013, 09:04 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Small single copper wire found running on various joists. What is this?
I've noticed this on a couple of different joists in my unfinished basement. At first I flat out thought it was just a piece of twine that was clamped to the joists, but yesterday I noticed what is apparently the insulation broken in one spot exposing a single copper wire. These look as old as the house (1930).
I can't really seem to track them to a destination but I did find 2 of them running through a hole in the rim joist to the outside, but there is no corresponding hole in the siding outside.
Any idea what this is / was for?
CoconutPete is offline   Reply With Quote
Old 01-07-2013, 09:06 AM   #2
"Nail-Bender"
A potential, fire hazard?!?
Are they live?
"RF"
rossfingal is offline   Reply With Quote
Old 01-07-2013, 09:09 AM   #3
Well it certainly doesn't carry high voltage, I honestly forgot to test for low.
The wire is very thin BTW, think ipod headphones after it has split into L/R and imagine just one of the sides - that's how thin it is.
Old 01-07-2013, 10:14 AM   #4
Sounds like door bell wiring.
ToolSeeker (01-07-2013)
Old 01-07-2013, 11:27 AM   #5
Or someone's long ago attempt to add a ground to ungrounded outlets. The ground wire used to be much thinner than the other two conductors.
Old 01-07-2013, 11:38 AM   #6
joed's Avatar
Sounds like door bell wiring to me also. Can you post a picture of the wire and anything it might be connected to. Might be telephone as well.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 01-07-2013, 11:53 AM   #7
SuperJETT's Avatar
What size are you walking about, very thin? Like the others mentioned, probably doorbell wiring. One of our previous houses was built around 1907 and was originally a 700sq ft shotgun but was 1800sq ft when we lived there. It had been changed tons, including where the outside doors were, so there was old doorbell wiring, etc etc throughout the place.
SuperJETT is offline   Reply With Quote
Old 01-07-2013, 12:39 PM   #8
I had a house that was built in 1911 and it had a single wire running outside and it terminated on a porcelain terminal block. Originally, an outside antenna was connected to it.
At one time the other end went to the family radio. Radio's at that time were usually tri-band tuners. Short wave, broadcast and long wave!
Old 01-07-2013, 01:23 PM   #9
I don't think it's telephone. I have found 2 diff. types of telephone wires in the house. The "modern" one which was obviously added after the fact and the older 3-wire style with the metal junction boxes - it doesn't look like any of those.
There is a doorbell transformer still present - it looks old, I honestly have no clue when it's from, but both it and the doorbell work fine and this wire in question is not near either of them.
It's not near any electrical boxes, so I don't think it's a grounding attempt either.
The radio thing sounds interesting.
I'll get some pictures later.
Old 01-07-2013, 03:34 PM   #10
joed's Avatar
I missed that it was a single wire. Either an antenna or a piece of knob and tube electrical wiring. Do you have a non contact voltage tester to see if it is live?
Old 01-07-2013, 10:20 PM   #11
Pics:
Small single copper wire found running on various joists.  What is this?-image-3900380964.jpg   Small single copper wire found running on various joists.  What is this?-image-4027290431.jpg   Small single copper wire found running on various joists.  What is this?-image-1631686196.jpg
Old 01-07-2013, 10:32 PM   #12
Missouri Bound's Avatar
Old telephone grounding wire?
Do you want it your way or the right way?
Old 01-07-2013, 10:55 PM   #13
I agree! The tip off is the cable mounting loops! Standard issue for phone wiring!
Old 01-08-2013, 04:01 AM   #14
paper hanger and painter
chrisn's Avatar
Originally Posted by Wildie;1088723[COLOR=red
]I agree[/COLOR]! The tip off is the cable mounting loops! Standard issue for phone wiring!
me too,I have the same in this house
Old 01-08-2013, 09:12 AM   #15
So by "old" telephone grounding wire, you mean they went along with the old 3-wire phone lines with the metal junction boxes which were replaced with the 4-wire ones later on right?
At a later time I want to move a duct on the other side of the basement, one of these things is in the way. It sounds like it would be OK to just chop this?
Where do you think the 2 that run through that hole in the rim joist go anyway?
Running low-voltage wire and data cables in parallel? bottlerockett Electrical 1 01-01-2013 06:35 PM
running power to detached garage / need need help w/ messenger wire mechanic30 Electrical 3 12-06-2012 06:59 AM
4 switches on a single wire dukewalsh Electrical 4 08-30-2009 06:57 PM
Adding 4 Recessed Lights to single wire themayor Electrical 5 02-05-2009 05:08 PM
Running wire ADKstorm Electrical 1 09-27-2007 12:43 PM
