Old 05-17-2010, 11:16 PM   #1
Just call me Andrew
Small screwless cover plates?
I wasn't taking the backsplash into consideration, and I mounted the outlet boxes about 1/2" too low for my cover plates (average size). What are my options? I prefer screwless.
Could I heat up the cover plate so I could maybe snip the bottom off?
Andrew
secutanudu is offline   Reply With Quote
Old 05-18-2010, 07:53 AM   #2
Licensed electrician
I don't even think the smallest plate would fit there without modification. Could you have the backsplash cut? It doesn't look like it is secured yet.
Old 05-18-2010, 07:55 AM   #3
Just call me Andrew
Having the backsplash cut isn't really an option - it's granite and a finished edge.
Andrew
Old 05-18-2010, 08:01 AM   #4
not the bottom
The older I get the better I was
Old 05-18-2010, 08:16 AM   #5
the Musigician
DangerMouse's Avatar
Is the plumbing all hooked up already?
I'd lay the cabinet down on it's back and saw off 1/2" from the bottom.
Problem solved.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 05-18-2010, 08:46 AM   #6
Using a fine tooth saw (or a coping saw?) you can cut the cover plate to match the edge of the countertop.
Hint: Saw slowly. Sawing always generates heat and if the plate melts then the saw blade gets stuck.
I think that heating the cover plate will yield less accurate results.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 05-18-2010, 08:53 AM   #7
Just call me Andrew
Cutting the cabinet isn't a terrible idea, but it kind of defeats the purpose of my higher countertops...though 1/2" isn't bad. I'll pick up a fine toothed blade on my way home.
One problem I see is that the screwless cover plates tend to snap on the bottom...i guess I might have to live with screws
Andrew
Old 05-18-2010, 08:59 AM   #8
the Musigician
It seems to me the simplest solution, and you won't even notice the half inch drop. Po)
*Good Luck!*
DM
Old 05-18-2010, 09:10 AM   #9
Just call me Andrew
*Good Luck!*
DM
Actually...it's not that simple...if it were 4 legs it would be, but trying to cut exactly 1/2" off the bottom of that vanity might be tricky.
Andrew
Old 05-18-2010, 09:46 AM   #10
Old School
Willie T's Avatar
For cryin' out loud. This is why there are "Madison" box clips. (Google "Madison Bars") or go HERE.
If you can move your receptacle a few inches, do so by pulling your wires, cutting a new hole, poking your wires out the new hole and through the Madison box... then pop the Madison box into place.
If you can't move it, pull the wires and cut the nails with a sawsall blade to free the box... cut the existing hole an inch or so higher, and remount with a Madison. (This one takes a bit more skill...)
Patch the old hole, (or the bottom of it in suggestion #2) and you're done.
Willie T
Old 05-18-2010, 10:44 AM   #11
Just call me Andrew
I've used Madison clips before - pretty easy. I'll think about that idea too - thanks!
Andrew
Old 05-18-2010, 03:33 PM   #12
Sparkaholic
Send a message via Yahoo to sparks1up
How about just turning the mudring so the receptacle is horizontal instead of vertical? That would gain you the distance you need and then some!
I can't tell by the pic, is that a 1900 box and ring or a romex plastic 2x4 box? If it is the latter I would cut the drywall and fix it right!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 05-18-2010, 04:02 PM   #13
Madison??? Lol I've always called em jiffy clips. Also, a sander works as well for whittling down a cover plate.
Andy-n-ATL is offline   Reply With Quote
Old 05-18-2010, 04:28 PM   #14
A "Handy Husband"
rjniles's Avatar
Madison clips?
I've always called them "battle ships" Turn them with bendable legs pointed up and you will see it.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 05-18-2010, 04:39 PM   #15
Just call me Andrew
It's a blue plastic nail-on box.
Andrew
Can a DIY build a small in-ground swimming pool? zel General Discussion 14 06-15-2013 10:42 AM
Small Animal Safety Sandramole Off Topic 6 01-24-2010 09:41 PM
12"x12" Tile Layout on SMALL (15"x24") Countertop? mirzai_m Kitchen & Bath Remodeling 6 01-11-2010 01:28 PM
small simple flat roof to cover an outside bar 60yroldnovice Roofing/Siding 1 09-09-2009 05:21 PM
Bottom plates are not pressure treated Richo Building & Construction 10 03-16-2009 06:48 PM
