Old 12-22-2012, 12:35 PM   #16
Small issue/ no clue, though
Those should be okay
Techy is offline   Reply With Quote
Old 12-22-2012, 01:14 PM   #17
JOATMON
ddawg16's Avatar
Are you useing a halogen or LED bulb? If halogen...temp is an issue....if your using LED....regular wire nuts will be fine.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 12-22-2012, 02:19 PM   #18
Missouri Bound's Avatar
He needs to use wire nuts suitable for the fixture rating.
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
frenchelectrican (12-22-2012), Oso954 (12-22-2012)
Old 12-22-2012, 05:57 PM   #19
Special User
Yup... next owners might swap out the LED bulbs for halogen.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is online now   Reply With Quote
Old 12-22-2012, 06:06 PM   #20
JOATMON
ddawg16's Avatar
Good point....didn't think of that...
My
and
The Following User Says Thank You to ddawg16 For This Useful Post:
Missouri Bound (12-22-2012)
Old 12-30-2012, 07:36 PM   #21
It uses a halogen bulb.
I'm not sure why we can't get ceramic connectors in Canada but I found these down in Ohio; I'm not sure what I should order exactly:
http://iseinc.com/Ceramic%20Wire%20Nut.htm
Non-handyman forever is offline   Reply With Quote
Old 12-30-2012, 10:41 PM   #22
Try an appliance parts store. They usually use the ceramic wirenuts for the ignitors in ovens.
paul100 is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
Would running a small duct through cmu be an issue? rgsgww HVAC 2 06-21-2012 01:32 AM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
