Small Issue/ No Clue, Though - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 05:41 PM   #1
Small issue/ no clue, though
A wire came out of this plate and I'm not sure how to repair this.
Here are the pics:
Small issue/ no clue, though-a1335501.jpg   Small issue/ no clue, though-3a8a266f.jpg   Small issue/ no clue, though-cb715ef0.jpg   Small issue/ no clue, though-35eadd77.jpg
Non-handyman forever is offline   Reply With Quote
Old 09-09-2012, 05:56 PM   #2
Electrical Contractor
kbsparky's Avatar
You need a new socket. It looks like a GU-10 socket from here ....
-KB
Old 09-09-2012, 06:04 PM   #3
Resi EC
Rewards Points: 252
I agree, don't think you can re-attach the wire, new socket
Gac66610 is offline   Reply With Quote
Old 09-09-2012, 06:27 PM   #4
Missouri Bound's Avatar
New socket required...and turn off the breaker if you haven't already. And call around before you drive around...may be a bit hard to find.
Do you want it your way or the right way?
Old 09-09-2012, 06:29 PM   #5
kbsparky's Avatar
You can get a new socket here.
Or, you can find them cheaper on ebaY.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Missouri Bound (09-09-2012)
Old 09-09-2012, 06:30 PM   #6
There you go!!!
Old 09-09-2012, 07:17 PM   #7
Guys, forgive me, I'm really hopeless...those wires go up behind everything. Do I pull out the aluminum thing for access and, if so, how do I remove it and what do I do to secure it back in there?
Old 09-09-2012, 07:37 PM   #8
A better picture.....
Small issue/ no clue, though-0cffd79a.jpg
Old 09-09-2012, 07:44 PM   #9
kbsparky's Avatar
You don't. Just cut the remaining wire, get a new socket, + a couple of porcelain wirenuts, and you're good to go!
-KB
Old 09-09-2012, 08:06 PM   #10
Do I use wire strippers on the old wire?
Old 09-09-2012, 11:09 PM   #11
" Euro " electrician
frenchelectrican's Avatar
You can use the wire stripper unit however some case it will work the best with uility knife due the insualting materal is differnt than conventail conductors are.
But make sure you get the porcelain wirenuts as KBsparky mention due the heat inside the luminaire. ( no plastique wirenuts please. )
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
tylernt (12-22-2012)
Old 09-10-2012, 12:20 AM   #12
Thank you very much for all the prompt replies.
Great bunch of people on this forum!
Old 12-21-2012, 09:27 PM   #13
Guys, they don't have porcelain wirenuts up here in Canada but I bought a pack of these:
http://www.tnb-canada.com/en/catalog..._marrcat_e.pdf
They are rated for temperatures up to 302 degrees Fahrenheit.
Would they be fine?
I am really clueless, guys, but is 'wire range' an important factor? The range is from 18 to 10.
Old 12-22-2012, 11:23 AM   #14
Bump.....
Old 12-22-2012, 11:33 AM   #15
Special User
Rewards Points: 1,230
http://www.yourwelcome.co.uk/blog/ha...omplete-guide/ says halogen GU10 can reach 482F.
Wire range is an issue, it looks like the wires in your fixture are 14ga or 16ga though so you should be fine. I recommend twisting the connections tightly with pliers before adding the wirenuts.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Would running a small duct through cmu be an issue? rgsgww HVAC 2 06-21-2012 12:32 AM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
