Old 07-21-2009, 03:09 AM   #1
Small heating coil
So I'm trying to create a small heating coil, maybe 1.5-2 inches in diameter, using a nichrome wire coil plugged into a standard 120v power outlet. Before doing any research on the subject I burnt out lots of wire and appliances, threw my breaker a couple times, etc. I've done internet searches but just can't seem to find the key to my conundrum. I need the coil to heat up and stay around 300 degrees Fahrenheit. I'm thinking that I need to create some sort of circuit board mediator between the coil and the outlet so the coil doesn't overheat like it did in my experimenting.
Does anyone have any insight?
hydr0lic is offline   Reply With Quote
Old 07-21-2009, 08:33 AM   #2
DIYer
Small heating coil
You need to understand ohm's law before you even attempt something like this.
Why don't you just buy a cheap hair dryer instead? The coil there is already designed correctly (though without moving air, will likely still overheat on "high")
Gigs is offline   Reply With Quote
Old 07-21-2009, 08:41 AM   #3
Xtreme DIY'r
Small heating coil
Is this just some experiment
Or are you trying to build something for a specific use?
Old 07-21-2009, 12:15 PM   #4
J. V.'s Avatar
Small heating coil
Yes, Whats the application? Heat water in your prison cell for Romain Noodles?
Old 07-21-2009, 12:42 PM   #5
Small heating coil
I'm guessing herbal vaporizor...
KeithM62948 is offline   Reply With Quote
Old 07-21-2009, 02:52 PM   #6
DIYer
Small heating coil
I hear temperature controlled soldering irons work fine for that.
Old 07-21-2009, 11:25 PM   #7
Idiot Emeritus
Small heating coil
A PTC (Positive Temperature Coefficient) thermistor might work.
This device will allow a large current flow when it's cold, and as it heats up, the current drops off. It'll maintain a temperature based mostly on voltage applied. If it's at operating temperature, and exposed to cold, it'll draw more current to maintain temperature.
Self-regulating heat tape is an example of a PTC thermistor, and there's one in nearly every CRT type TV and computer monitor. Same principal, different purposes.
Rob
micromind is offline   Reply With Quote
Old 07-22-2009, 05:31 AM   #8
Electrical Contractor
kbsparky's Avatar
Small heating coil
You looking for something like this?
-KB
heating & cooling small loft Master Brian HVAC 2 05-22-2009 12:09 PM
Proper Voltage for small Nichrome heating element. Dacr0n Electrical 8 01-19-2009 12:30 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
