-   -   Small gauge extension cord on a 12 amp circuit? (http://www.diychatroom.com/f18/small-gauge-extension-cord-12-amp-circuit-165017/)
chuck2112 11-28-2012 05:07 PM
I'm running xmas lights all over my house and using 16 gauge extension cords (under 25') to get power to them. My outside receptacles are all 12 amp and my question is this: What is the rule about plugging smaller gauge extension cords into higher amp receptacles?
This is a question I've had for a while. Thanks for your help.
joecaption 11-28-2012 05:11 PM
There is no rule, those lights draw so little amperage it's not going to be an issue.
If you used the same cords to try and power something else like a table saw
Then it would be an issue.
chuck2112 11-28-2012 05:18 PM
So are you saying that the source power isn't the factor here, it's the load that is important and smaller conductors aren't affected simply because of the small load? So for this example, my max load with a 16 ga cord is about 1200 watts?
seansy59 11-28-2012 05:42 PM
14 Attachment(s)
First, it is probably a 15 or 20 amp circuit. No such thing as a 12 amp circuit in a house. To ease the pain, I will follow this with a smiley face :)
Christmas lights usually only draw about 1-2 amps, and that's a lot of lights on one cord.
A 16 gauge cord under 25ft can handle about 1,250 watt comfortably and safely. As the length grows, the capacity becomes smaller due to resistance and heat buildup (this is why fires start).
You can plug a 16 gauge cord into a 200amp outlet (doesn't exist) with no load plugged in. It wouldn't do a thing, that is, until you started drawing a load. What matters is what you plug into it and how much it draws.
It is ideal though to have wiring protected as much as possible. Personally I thing no cords should be made smaller than 14 gauge, which is 15 amps. Usually the smallest circuit allowed in a house. Or at least have built in permanent 10-12a fuses in smaller 16ga cords, since many people tend to overload them.
chuck2112 11-28-2012 05:47 PM
I messed up when I said a 12 amp circuit, I meant 20 amp (or 12 gauge). Thanks for the good info, now I'm all set to Griswold my house.
dmxtothemax 11-29-2012 03:25 AM
YES !
Quite correct !
AllanJ 11-29-2012 05:36 AM
Oops! Circuits with ordinary (15/20 amp) receptacles and ordinary ceiling and similar light fixtures may not be breakered at more than 20 amps.
Any approved extension cords (some have 18 gauge wire) and lighting (some Christmas strings have 20 or 22 gauge wiring) may be plugged into such circuits. It is up to the user to determine what load he has placed on an extension cord.
seansy59 11-30-2012 01:20 PM
14 Attachment(s)
LOL....thats why I have "(Doesn't exist)" in the sentence. :laughing: :)
Also, good luck wiring 200amp 4/0 aluminum to a small 15/20amp outlet. :laughing: Although, I am sure some idiots have found a way to do it and end up burning down their house in the process. :whistling2:
tylernt 11-30-2012 03:05 PM
12AWG pigtail and a really big wire nut?
seansy59 11-30-2012 04:26 PM
14 Attachment(s)
:laughing::eek:
