Small Electric Heater Recommendation - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 01:55 AM   #1
small electric heater recommendation
I am trying to heat up a small 6x12 enclosed trailer as quickly as possible. It is finished out and insulated. Actually one of those small $20 1500 watt portable 120v heaters will do the job but it takes a while.
My problem is this trailer houses some computers that won't even turn on until it is about 45 degrees. Often on cold mornings when we arrive on the jobsite and fire up the generator it takes a while to reach this temperature which delays my whole crew getting started.
I am looking for something either 120v or 240v that will heat it up in a hurry. I was thinking 4 of the 1500 watt small heaters would do the job but maybe there was something better? I have looked around in the home improvemnet stores and have not seen anyrhing over 1500 watts.
I have a 10,000 watt generator to power it.
bdog1234 is offline   Reply With Quote
Old 02-24-2008, 08:23 AM   #2
Rewards Points: 1,274
NOTHING electric is going to heat a space that size quickly. Try a small LP gas in-wall heater that can run at all times w/o electricity.
LawnGuyLandSparky is offline   Reply With Quote
Old 02-24-2008, 09:50 AM   #3
Rewards Points: 246
Never heard of a computer not loving cold air. Just leave them on all night. Change the settings so they will not sleep or disconnect the fan on the processor.
If it worked before you worked on it. You did something wrong.
Old 02-24-2008, 09:51 AM   #4
Electrician
I dont think he wants to run the generator all night...
chris75 is offline   Reply With Quote
Old 02-24-2008, 01:28 PM   #5
Thanks for the replies. This computer is not a regular computer. It is a specialized piece of equipment that for some reason does not want to turn on until about 45 degrees and it wants to shut off at 100 degrees.
Leaving the generator on all night it not really an option.
I am not needing it to heat up in seconds, but quicker than one 1500 watt heater.
Right now we get there about 7am, and it may be 10 degrees. Start generatror and heater and it is 45 degrees inside by 8am. Little heater has it so hot in there I have to turn it off by 10 am.
Old 02-24-2008, 01:30 PM   #6
Electrician
The answer is simple, get two heaters . In theory it will heat twice as fast...
Old 02-24-2008, 01:37 PM   #7
How about using an electric blanket and wrapping the computer tower. Turn the blanket on when you first arrive. Do not cover the cooling vents.
redline is offline   Reply With Quote
Old 02-24-2008, 01:41 PM   #8
This will work, as would the blanket. Good idea on the blanket.
I was just wondering if there was a more "permanant" solution. Instead of two portable 1500 watt heaters that must be plugged in a 3000 watt heater that is hard wired and mounted to the wall.
Old 02-24-2008, 01:50 PM   #9
Electrician
Yes you can get a 5kw if you want...http://www.heater-home.com/product/G73.aspx?ref=froogle
Old 02-24-2008, 02:12 PM   #10
If you were to aim the heater at the computer tower then it should warm up faster then waiting for the entire room to heat up. Re-aim the heater away from tower once it is up to temp.
new electric water heater - Vacuum breaker necessary? J187 Plumbing 12 05-26-2012 08:42 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Choosing an electric water heater brand? coyote556 Plumbing 6 11-06-2007 09:57 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
Electric Hot Water Heater Cooked? bobo Electrical 7 09-09-2005 06:45 PM
