Slot 3 In My Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 08:54 AM   #1
Slot 3 in my breaker box
Hi all,
I have a new Homeline sub-panel and I tried to put a 15a beaker in slot 3 to no avail. When I moved it down a slot it worked fine. Just curious as to the why.
Hope you all have a nice Sunday.
Brock
BrockEmerson is offline   Reply With Quote
Old 04-21-2013, 09:09 AM   #2
Electrical Enthusiast
Rewards Points: 504
Is it a tandem breaker? (Two miniature breakers in one slot)
Kyle_in_rure is offline   Reply With Quote
Old 04-21-2013, 10:37 AM   #3
joed's Avatar
Rewards Points: 12,362
It wouldn't go in or didn't work when installed?
Old 04-21-2013, 11:12 AM   #4
Single breaker. Snapped in, no voltage measured between breaker and neutral bus.
Old 04-21-2013, 03:11 PM   #5
joed's Avatar
Bad slot, burnt busbar in the slot 3.
Old 04-21-2013, 07:32 PM   #6
Electrical Contractor
kbsparky's Avatar
SOME panels have dummy slots which are not designed to accept a breaker. You can plug a breaker in, but it will not work, since there is no bus-bar present in that slot. Usually opposite from a main.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Philly Master (05-19-2013)
Old 04-29-2013, 11:53 AM   #7
My elec did figure out what was causing the drop in voltage in a few of my panel slots..... because mineral grease (de-ox) was never put on the bus bars in the factory, they oxidized a bit in spots and that created some resistance. He got them clean and greased up and the problem went away.
Old 05-19-2013, 06:26 PM   #8
Rewards Points: 16
What did your electrician use (or what is a good cleaner) to remove oxidation from buss bars?
saltpeter is offline   Reply With Quote
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 09:34 PM
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 09:57 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
