Slight Twist In 2/12 NM-B - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 01:52 AM   #1
Rewards Points: 83
Slight twist in 2/12 NM-B
Hi. While looking around at the other wiring in my house after finding a cable in my return air duct. I found this section of yellow 2/12 NM-B. It is all stapled very flat and looks to run pretty well except when they made a turn through a hole to cross between two joists a section has a slight twist to it across the two foot joist space. Is this a problem or nothing to worry about. Here is a picture of the yellow twisted section. This is the only section that has the twist.
pex006 is offline   Reply With Quote
Old 07-14-2013, 05:20 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Wow! I hate to sound like a jerk, but are you actually asking if this is a problem???
You haven't seen much wiring, have you?
To some here this would even seem like a troll post.
Speedy Petey is online now   Reply With Quote
Old 07-14-2013, 06:08 AM   #3
biggles's Avatar
rip it out.... kiddin' that stuff can be twisted and turned like a spring on your car suspension...but what about that cable in your duct work.... did they drill a whole and slide it thru..so the wire is raw on the sheet metal hole with air bouncing the cable...over the years.... couple of wire ties to that white pair
Old 07-14-2013, 10:53 AM   #4
Rewards Points: 83
Sorry. Not a troll. Just read on the net that the wires shouldn't have twists or there might be hot spots. I thought it was probably ok, but thought it might not hurt to ask. The cable that goes in the air return is a different cable and it is in a wood stud bay they used as a cold air retun. I comes in through a wood stud and exit though the wood top plate. All the cables in this picture run below the ducting in the ceiling joists of the basment. None of these go through or near the duct.
Old 07-14-2013, 10:55 AM   #5
Rewards Points: 150
This is a DIY site so this is a valid question now on a pro site it would be a joke.
RIP EJT
usair is offline   Reply With Quote
Old 07-14-2013, 10:58 AM   #6
Rewards Points: 6,652
So what is the problem again?
2/12 pitch trusses questions... BFT Roofing/Siding 15 01-10-2012 06:04 PM
PVC, is twist necessary? lmbgm Plumbing 7 11-11-2011 09:07 AM
is there a trick to twist fitting type B vents amakarevic HVAC 4 07-14-2011 10:08 PM
240 twist lock to two 120v 20 amp plugs MLMIB Electrical 7 03-10-2011 12:17 PM
The Twist john4153 Plumbing 2 10-23-2010 09:05 AM
