Slight "sizzling" Sound Coming From The Box - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 09:46 AM   #1
Rewards Points: 27
Slight "sizzling" sound coming from the box
Great...just great....
I have the guy mudding my basement right now and he just told me my lights flickered a couple times and then went dead. I reset the breaker in the subpanel and they came back on. Then went off a minute later. When I flipped the breaker, I noticed a slight "sizzling" sound coming from the box. I only have the one circuit up and running right now and the sound stopped when I flipped it off. I shut off the whole panel just to be safe for now.
I'm really hoping it is a bad connection in there or a bad breaker. REALLY HOPING.
Has anyone run into something like this before?
jailbird371 is offline   Reply With Quote
Old 02-25-2011, 09:53 AM   #2
Licensed electrician
Rewards Points: 1,508
The sizzling sound makes it sound like arcing from a loose connection. You need to find it before the connectio deteriorates, especially if it is in the panel and you are burning the buss.
Old 02-25-2011, 09:56 AM   #3
I had a problem like this in December. I thought it was a bad breaker, but wasn't.(Although I think it could possibly be that as well).
My problem was that the lug in the box where that breaker connected had been badly burned and pitted from a problem that happened
two years prior with an overloaded circuit that repeatedly tripped that breaker(comb. of too many xmas lights and crummy wiring).
Anyway, long story short, I too thought it was a bad breaker and changed it. No good. Still had the problem.
I had to call an electrician, who was too busy to come, but was nice enough to tell me what was wrong.
My solution was to not use that slot in my panel and move the circuit to another open slot. That fixed it for me.
I'm not an electrician and I'd wait to get another opinion from one of the pros, but I'd leave that breaker off until you can get it resolved
tmorriss is offline   Reply With Quote
Old 02-25-2011, 10:03 AM   #4
Rewards Points: 27
This is in my subpanel. I cut power to the whole thing from the main box. I think I'm just going to leave it off and call my electrician in a couple days when the mudder is done. I'm waiting because my utility room is just loaded with all the stuff from the rest of my basement while the guy tapes and muds.
Old 02-25-2011, 11:54 AM   #5
Rewards Points: 27
Phew...just got off the phone with my electrician. He said if I felt comfortable to open up the panel and check for loose connections....obviously with the power off. Sure enough the power running to the breaker in question was very loose. I could pull it out by hand. Tightened everything back up and all is well. He said he'd stop by tomorrow to double check everything. I'm so glad it was a simple and cheap fix.
Old 02-26-2011, 12:49 AM   #6
Scared Electrician
Saturday Cowboy's Avatar
sounds like a screw got a wire somewhere and the drywallers mud completed the circuit
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 08:35 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
Water sound in Pipes Robb Plumbing 14 12-26-2006 10:48 PM
