Slices Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 04:39 AM   #1
Slices romex
2 part question.
Cleaning up the attic space when I noticed that a blue romex cable had a cut into it. Examining it it seems it was snagged when being pulled again a staple and cut into the outer plastic. The black and white are intact but the ground was severed.
Tracing what outlets it eventually went to I found that it showed open ground when using one of those 3 prong plugin testers.
Section that is cut goes from the garage door opener outlet to the attic light fixture.
What's the best way to fix it, junction box or re-run it. Right now just wrapped it with some 33 tape. Picked up some 12/2 cable as well as a box until I decide what to do. Since the current cable is blue and replacement is yellow, the cable wil stick out as much as a j-box.
Second part, far fetched I know. Anyway to go after the previous owner/inspector? PO had a bunch of crap in the attic, had they not, one would have spotted it a mile away.
toastandjam is offline   Reply With Quote
Old 11-06-2012, 04:53 AM   #2
Julius793's Avatar
If you have a little slack cut it and throw it in a j-box
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 11-06-2012, 09:29 AM   #3
concretemasonry's Avatar
Rewards Points: 2,578
It is possible the previous owner knew of the problem and out the junk there since he was moving. A home inspection (usually contracted by a buyer) is a visual inspector and an inspector is not allowed to move too many things because of possible damage. It is done commonly when people put boxes in a basement area to hide wet floor/leakage signs. Since the inspector is actually a guest he cannot disturb too much because of the liability compared to the low inspection fees paid. A good inspector may be able to find other signs to post a "red flag" for the potential flag. The inspector was probably recommended by a realtor.
Dick
concretemasonry is online now   Reply With Quote
Old 11-06-2012, 06:34 PM   #4
Inspector came from other referrals than my realtor. Since the cable in question is easily accessable to disconnect both ends and replace, will probably end up doing that as well as installing a better attic light and toggle switch than a pull chain that is there now.
Old 11-06-2012, 06:36 PM   #5
Just install a junction box. If the wire is stretched too tight, then install 2 junction boxes with a 2 foot piece of romex in between them.
Gensetter is offline   Reply With Quote
Romex on basement wall to panel iceclimber2001 Electrical 3 08-13-2012 08:40 AM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
