Old 10-17-2012, 03:56 PM   #1
Slater receptacle
The Slater receptacle has a white wire and a black wire. It also has a stripped wire. Are the black and white wires suppose to be stripped also?
Lorenzo Currin is offline   Reply With Quote
Old 10-17-2012, 04:39 PM   #2
Master Electrician
Slater receptacle
Is this a GFCI with attached leads?
brric is offline   Reply With Quote
Old 10-17-2012, 06:51 PM   #3
Electrical Contractor
kbsparky's Avatar
Slater receptacle
If anything says "Slater" on it, take it to your nearest trashcan!
Those things are J-U-N-K!
-KB
Old 10-17-2012, 07:45 PM   #4
Common Sense Common Guy
Slater receptacle
I 100% agree! My home was full of Slater / PS receptacles and switches. After only 10 years of service, half the receptacles would no longer hold plugs reliably, and switches began burning out. Dump it.
flasherz is offline   Reply With Quote
Old 10-17-2012, 08:17 PM   #5
Licensed electrician
Slater receptacle
Ten years of service from something that might have cost 30 cents seems like a good deal.
brric (10-17-2012)
Old 10-17-2012, 08:50 PM   #6
Slater receptacle
Perhaps... or you could consider that an investment of 15-20 cents more per device could give it 4-5x the life, plus the significant cost in time (whether my own or paying for an electrician's), not to mention the mental wear & tear of having wall-warts fall out, or plugs not remain securely in place.
Bottom line - don't skimp... it's not worth it.
Old 10-18-2012, 04:18 AM   #7
kbsparky's Avatar
Slater receptacle
It should be noted that after P&S acquired Slater, they began to realize they were pushing nothing but junk. P&S was commonly called "piece of sh**"
Their previous marketing battles with Slater seemed to be "who can make the worst, cheapest, junk"?
One day, they woke up and did something about it: They scrapped their junk lines and redesigned the entire line of wiring devices.
Now P&S stuff is better than most, even the builders' grade of devices. Many contractors prefer them over Leviton, GE, or Eagle/Cooper, whereas before they were avoided like the plague.
-KB
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 02:18 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 01:07 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 02:04 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
