Old 12-04-2012, 10:31 AM   #1
Skinny on AFCI
I am rewiring a couple of bedrooms and have been reading conflicting info on AFCI - I hope someone can give me the straight goods.
1 - Does the requirement for new construction to have AFCI protection for lights and outlets in nearly all 'habitable areas' have any bearing on remodels?
2 - I have read both that hard wired smoke detectors should only be on AFCI protected circuits and also, that they should never be. Which is it?
3 - On a related side note, do I need to keep Cat6 and coaxial cables separated from electrical cables?
Thanks.
Windows is offline   Reply With Quote
Old 12-04-2012, 10:58 AM   #2
Licensed electrician
Skinny on AFCI
Normally, any new installation needs to meet the codes enforced at the time, regardless of new construction or remodel.
The NEC requires the smoke alarms to be AFCI protected.
Old 12-04-2012, 12:09 PM   #3
Skinny on AFCI
All depends on the code version you fall under. Jurisdictions don't always immediately update to a new version of a code. When I built my house in 2009, the applicable code was NEC 2005. Only the bedrooms were required to have AFCI protection.
Old 12-04-2012, 04:55 PM   #4
E2 Electrician
stickboy1375's Avatar
Skinny on AFCI
As a side note, some states have amendments not requiring smokes to be AFCI protected such as Connecticut, so its really in your best interest to check your states websites for state electrical amendments.
This applies to other code sections in the NEC as well, not just AFCI's and Smokes, I was just using it as an example.
Old 12-05-2012, 01:26 AM   #5
Skinny on AFCI
THanks for the help. THis project is starting to come together.
Old 12-05-2012, 01:42 AM   #6
Skinny on AFCI
When did NEC go into effect AFCI and smoke alarm.
Hardway is offline   Reply With Quote
Old 12-05-2012, 05:22 AM   #7
E2 Electrician
Skinny on AFCI
2005 I believe. Afci is required for every outlet in every bedroom, a smoke alarm is an outlet.
Old 12-05-2012, 06:39 AM   #8
Licensed Electrician
k_buz's Avatar
Skinny on AFCI
Feed the smokes with some other existing circuit, then they don't have to be AFCI protected.
Location...Location...Location
Old 12-05-2012, 06:47 AM   #9
E2 Electrician
Skinny on AFCI
I don't understand? A smoke alarm is an outlet, therefore requires afci protection unless your state has an amendment.
Old 12-05-2012, 06:53 AM   #10
k_buz's Avatar
Skinny on AFCI
We are on 2008 and only require AFCI's on new circuits.
Old 12-05-2012, 09:06 AM   #11
Skinny on AFCI
Yes, 12" and cross at 90 degrees.
herdfan is offline   Reply With Quote
Old 12-05-2012, 09:26 AM   #12
Skinny on AFCI
AFCI requirements started in the 1999 NEC with an adaption in 1/2001 IIRC for bedroom receptacles. The next step was bedroom outlets. The requirement has expanded since then and now covers most areas not protected by a GFI.
Old 12-05-2012, 10:02 AM   #13
Skinny on AFCI
Time flies and it was late at night when I read this. I was aware of AGFI for outlets, was not concerning smoke alarms. How ever as I read this, this morning, it is over ten years since the place was built and wired. I am a bit behind on the code, by reading DIY I catch up. Thanks for the info.
Old 12-05-2012, 11:00 AM   #14
Lic Electrical Inspector
electures's Avatar
Skinny on AFCI
K Buz, what state?
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 12-05-2012, 11:51 AM   #15
k_buz's Avatar
Skinny on AFCI
Wisconsin
The Following User Says Thank You to k_buz For This Useful Post:
electures (12-07-2012)
Standard Circuit and AFCI? tomatoguy Electrical 5 02-19-2012 08:50 AM
AFCI breaker tripping encounter779 Electrical 8 06-11-2011 05:09 PM
Puzzled with AFCI nuisance trip ravi Electrical 11 06-06-2011 06:27 PM
Need help understanding GFCI & AFCI sheslostcontrol Electrical 14 11-01-2010 12:59 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 08:21 PM
