Size Of Wire & Type Of Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2009, 03:52 PM   #1
Size of Wire & type of wire
I have a new detached garage 150 ft from the main box I want 220 & 110 underground (no conduit) type wire. I will run a small 220 air compressior and some 110 power tools. What size wire and type of wire?
agman is offline   Reply With Quote
Old 11-10-2009, 04:04 PM   #2
What does the compressor draw for amps?
Any AC or heat out there?
What size main panel do you have?
What other large electric draws do you have in the house ?
Old 11-10-2009, 04:37 PM   #3
You need to make that decision based on the current requirements of each circuit you will install. Also you should reconsider your intention of going with direct burial cable. If you go to all the trouble of digging a trench you might as well be put in conduit and if you oversize your conduit you can pull another circuit later when you buy some tool you never thought you would buy.
trosenda is offline   Reply With Quote
Old 11-10-2009, 06:08 PM   #4
joed's Avatar
Rewards Points: 12,028
You can't pull more than one circuit to a detached building. If you need multiple circuits you must pull a large feeder and install a sub panel.
Old 11-10-2009, 06:08 PM   #5
Install 1" PVC conduit, 18" deep with 3 # 6 THWN wires (2 black hots, 1 white neutral) and 1 #10 green ground.
Install a sub panel at the garage, keep the neutral bus isolated from the enclosure, install a ground bus kit and run a #6 bare wire to two 1/2" x 8' ground rods spaced at least 6' apart.
Install a 2 pole 60 amp breaker at your main panel to feed the garage panel.
220/221 is offline   Reply With Quote
Old 11-10-2009, 06:30 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 258
YEAH, What he said
jbfan is online now   Reply With Quote
Old 11-10-2009, 09:13 PM   #7
Idiot Emeritus
Rewards Points: 1,492
220s advice is the best. It'll be easy, and provide all the power needed for a shop.
Rob
micromind is offline   Reply With Quote
What size and type of nails to use keviadams General DIY Discussions 2 09-28-2009 01:25 PM
wire size for ac/heating forced air unit macfluke Electrical 2 03-04-2009 01:29 AM
range wire size mikalino Electrical 11 02-12-2009 09:52 PM
Size wire for Dryer Bigbobdallas Electrical 2 02-02-2009 12:47 PM
wire size for solar generator? krisman Electrical 12 01-28-2009 11:34 PM
