Size Wire For Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 12:17 PM   #1
Size wire for Dryer
I need to know the correct size to use to come from the breaker box to the dryer. Also what is the recommended size breaker that this should have for the 220 dryer.
Bigbobdallas is offline   Reply With Quote
Old 02-02-2009, 12:41 PM   #2
Licensed Pro
Typical residential dryer in the US requires 10/3 w/ ground, a 30A double pole breaker and a 14-30 (4 prong) receptacle.
Old 02-02-2009, 12:47 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Read your installation instructions carefully for the differences in 3 and 4 wire connections. New installations require 4 wires H-H-N-Grd like you will have with 10/3 G as househelper stated. A new dryer may likely come with the dryer configured for a 3 wire connection. Follow the instructions on how to remove the frame bond to the neutral terminal to convert to a 4 wire connection if necessary
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Wire size for dryer jamiedolan Electrical 14 01-15-2009 06:43 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Aluminum wire size/ guage / amps? walt1122 Electrical 17 07-30-2008 11:44 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
