-   -   Size of wire and breaker (http://www.diychatroom.com/f18/size-wire-breaker-149951/)
dwagg 07-11-2012 04:45 PM
I am installing a couple of 60watt lights and a sprinkler control box and a small water feature pump. i will have a run of about 325 feet. what size of wire and what size of breaker for the main run to a small sub panel with 3 breakers of 15 amps for the lights, sprinkler and fountain pump?
curiousB 07-11-2012 04:52 PM
Doesn't seem like this would draw much so three 15A circuits sounds like overkill. Do you know power draw of fountain pump? Sprinkler controller is probably less than 25W.
I think a single 14-2 UF cable fed by a single 15A breaker with a GFCI receptacle instead of a breaker panel at the remote point then slave the lights, pump, and sprinklers off of the load side of the GFCI. You get a 120VAC outlet as an extra bonus.
stickboy1375 07-11-2012 05:21 PM
12 Attachment(s)
If I'm digging 325', I'm installing conduit, and leaving provisions for the future, without seeing what you are actually doing, I might pull #6AWG, to a remote panel...
andrew79 07-11-2012 05:27 PM
Go big or go home lol. Probably need a number 6 anyways at that distance. Taking a random number of 8a you would need a number 8 wire to get it out there.
Julius793 07-12-2012 10:55 PM
Make sure you install pull Boxes if there are to
many 90s
