Size Of Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 08:12 AM   #1
Smile
Size of wire
I am running 110 electrical to a storage barn that is 150 ft away from my house. I will have a few lights and a few oulets all 110, what sie wire should i use?
BIRDE is offline   Reply With Quote
Old 05-28-2011, 08:16 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Depending on the load I'd say #10. #12 will work if the only load is some lighting.
The Following User Says Thank You to Speedy Petey For This Useful Post:
BIRDE (05-28-2011)
Old 05-28-2011, 10:42 AM   #3
Rewards Points: 460
It depends if you're running a new run from the main box or tapping off an existing circuit at some kind of junction. If it's the second, you are limited by the existing condition. If it's a 15 amp circuit (on breaker at main box), use only #14. If it's a 20 amp circuit, use #12. That's all after you've determined existing load on the line.
If the circuit being tapped has low usage items (ie not a refrigerator) that will not be in use when using your barn, should not be a problem. That means power equipment etc. 20 amp or higher would be better than a 15 amp so use #12 wire and 20 amp breaker or better if tapping off main box.
diyorpay is offline   Reply With Quote
Old 05-28-2011, 11:40 AM   #4
Rewards Points: 58
http://www.liteco.ca/Portals/_Rainbo...calculator.htm
Old 05-28-2011, 12:06 PM   #5
This is very misleading. Are you saying he HAS to stay with #14 on a 15A and #12 on a 20A?? If so then this is wrong.
He can use bigger wire to compensate for voltage drop, even if it is tapping off an existing circuit. This is not an ideal situation, but it is completely legal and probably better than staying with the same size.
This confuses me to the point that I have no comment.
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 10:41 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
