Size A Subpanel - Kitchen Feed - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 02:15 PM   #1
WaldenL's Avatar
Rewards Points: 268
Size a subpanel - Kitchen feed
Since I need more breaker slots anyway, I figure I might as well install a sub panel closer to the kitchen remodel and just have one run from main to sub, and then 7 runs from there to kitchen. Question is, how large should the sub panel be? (amps, not inches ) There are (well, will be):
2x 20A small appliance incl. refrigerator and gas range
20A micro/hood
15A lighting
20A outdoor and tv in kitchen (6' off floor, shouldn't need to be SABC)
20A D/W and disposal
1 15A for hardwired fire (not specifically for kitchen, but in same project)
Add them up and that's 130A, but obviously they're not all 100% loaded all the time. So how does one size the sub panel? Does the code say anything here?
It would be stupid, but could I have a 20A sub panel? Would that meet code?
More realistically, how's a 60A look? 6ga wire run, right?
WaldenL is offline   Reply With Quote
Old 09-23-2009, 04:04 PM   #2
Code05's Avatar
Rewards Points: 1,104
60 amps will be fine. I can show the load calc., but i am a slow typer. PM if you want it and i will type it when i can.
Code05 is offline   Reply With Quote
Old 09-23-2009, 04:58 PM   #3
50A is fine also.
220/221 is offline   Reply With Quote
Old 09-23-2009, 09:07 PM   #4
I'd do the 60a, a 20a would be a waste of time
Old 09-24-2009, 07:32 AM   #5
WaldenL's Avatar
Rewards Points: 268
I was not seriously suggesting 20A, except to ask if it would "meet code." I don't see anything about minimum sub panel size.
Can I get a confirmation on 6ga for 60A?
Old 09-24-2009, 07:56 AM   #6
I have a 60a 6g sub going to my pool cabana in conduit
I was actually told at one point I could go to 70a
But never checked into it as I don't need that much power
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Subpanel help? Killertea08 Electrical 16 09-30-2008 09:40 AM
wire feed size for dble oven setup ? ? ? yes.itsconcrete Electrical 29 09-12-2008 09:11 PM
Subpanel question James Con Electrical 1 02-11-2008 10:52 AM
