Size And Location Of Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 06:38 AM   #1
WHH
Size and location of breaker box
I have a 1 bedroom apt. (900 sq. ft.) in NYC and the breaker box is in the bathroom. I am being told by the electrician that in order to bring the box up to code, it has to be relocated and cannot be in a bedroom or closet. Is this true? Also, he says the size of the new box is 24" high and 14.5" wide. That seems awfully big to me. Can anyone confirm if this is true and accurate for New York City? Thanks.
WHH is offline   Reply With Quote
Old 03-02-2013, 06:58 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It's basically true. Panels cannot be installed in a clothes closet or near combustible materials. The panel also needs a set working clearance surrounding it...30" wide and 36" deep...the 30" does not have to be centered on the panel. Bedrooms are fair game in my area, but I don't know your layout.
The panel's physical size seems about right. Most are a full stud space wide...14 1/2".
Old 03-02-2013, 07:26 AM   #3
Master Electrician
Rewards Points: 3,870
OCPD,s may not be located in clothes closets or bathrooms per the NEC. Bedroom prohibition may be a local requirement, not NEC.
brric is offline   Reply With Quote
Old 03-02-2013, 08:06 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Locate in a hall and hang a picture over it. Size sounds right for a typical 100 amp panel.
Coastal South Carolina
rjniles is offline   Reply With Quote
Return air grill size, location, construction autx790 HVAC 15 08-09-2011 11:37 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
Odd stud size and location? help? mbrown4844 Home Theater 9 03-01-2011 09:37 PM
Subpanel location and size PhillyRyan Electrical 5 08-18-2010 03:49 PM
Number, Size, and Location of Celing Vents GeauxCajuns82 HVAC 7 11-13-2008 10:40 AM
